#define _XTAL_FREQ = 20000000;
should probably be
#define _XTAL_FREQ 20000000UL
I dont know what the intention of the other define, will it even compile?
#define _XTAL_FREQ = 20000000;#define _XTAL_FREQ 20000000ULdefine _delay_ms();#define SOMETHING = 20;
unsigned char test = SOMETHING;unsigned char test = = 20;;if you read the posting I already included xc.h__delay_ms() is part of the library, you just need to include xc.h to use it.
As the others mentioned thats really basic stuff, get a tutorial/book and follow it.
user2009 wrote:Without reading that configuration, your defines are wrong.
should probably be
There is nothing wrong with the original version.
It is used as part of a calculation inside another compiler defined macro.I dont know what the intention of the other define, will it even compile?
