Device configuration
Re: Device configuration
Postby user2009 » Mon Jul 21, 2014 3:01 pm
Without reading that configuration, your defines are wrong.
#define _XTAL_FREQ = 20000000;
should probably be
#define _XTAL_FREQ  20000000UL
I dont know what the intention of the other define, will it even compile?
user2009
Postby Dimebag » Mon Jul 21, 2014 3:05 pm
I am lost again if its just a warning or, in fact I have a problem. (BlinkLED.c:4: warning: (111) redefining preprocessor macro "__delay_ms")
Dimebag
Postby Dimebag » Mon Jul 21, 2014 3:09 pm
Thank you, user2009
May I ask why #define _XTAL_FREQ 20000000UL?
Dimebag
Postby user2009 » Mon Jul 21, 2014 3:12 pm
__delay_ms() is part of the library, you just need to include xc.h to use it. You redefine that function/macro by doing this
define _delay_ms();
(you dont want to do that)
Edit: A macro is just text replacement.
#define SOMETHING = 20;
unsigned char test = SOMETHING;
will be expanded to
unsigned char test = = 20;;
You can see whats wrong with it that way.
As the others mentioned thats really basic stuff, get a tutorial/book and follow it.
user2009
Postby Dimebag » Mon Jul 21, 2014 3:20 pm
#define delay_ms(); Complied. Why?
Dimebag
Postby Dimebag » Mon Jul 21, 2014 3:43 pm
if you read the posting I already included xc.h
Dimebag
Postby Dimebag » Mon Jul 21, 2014 3:46 pm
If you know of any useful tutorials and books I should be reading, please let me know.
Dimebag
Postby Dimebag » Mon Jul 21, 2014 3:57 pm
user2009, I just read all 6 posts you have done here. Help someone else. Thank you for your assistance.
Dimebag
Postby ric » Mon Jul 21, 2014 9:23 pm
user2009 wrote:Without reading that configuration, your defines are wrong.
should probably be
There is nothing wrong with the original version.
It is used as part of a calculation inside another compiler defined macro.
I think it was an attempt to stop MPLABX putting a red squiggle under _delay_ms() when it is invoked. Yes, the define should NOT be there.
That is a bug in the MPLABX editor, it compiles just fine,
Postby user2009 » Tue Jul 22, 2014 6:35 am
You need to obtain some general basic knowledge of C language.
user2009
