Device configuration
Re: Device configuration
Postby Dimebag » Sun Jul 20, 2014 2:09 pm
Tom, I wasn't side tracked. I will move to PIC24/PIC32 after I understand C for embedded devices. I am asking for help to understand the basics of C/C++/Header/Linker/etc. I am looking at PIC24/PIC32 for later use. My knowledge base is very poor. In the meantime I just want to improve my understanding of the tech behind the complier. I understand the device I selected is out dated by the new MCU's standards. I am only asking for direction to advance my knowledge base.
Dimebag
Postby Dimebag » Sun Jul 20, 2014 2:12 pm
PIC32 is of interest to me currently.
Dimebag
Postby Dimebag » Sun Jul 20, 2014 2:15 pm
Updated code for 18F452 @ 20 mhz
//Configurations and Fuses
#pragma config  OSC = HS, OSCS = OFF,PWRT = ON,BOR = OFF
#pragma config  BORV = 45,WDT = OFF,WDTPS = 1,CCP2MUX = OFF
#pragma config  STVR = OFF,LVP = OFF,DEBUG = OFF
#pragma config  CP0 = OFF,CP1 = OFF,CP2 = OFF,CP3 = OFF,CPB = OFF,CPD = OFF
//PORTB pins.
char array[9] = {0x80, 0x40, 0x20, 0x10, 0x08, 0x04, 0x02, 0x01};
//Timer values.
char offset[20] = {0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80,
//char temp = 1;
char temp = 2;
int inside = 0;
int outside = 0;
int scanPin = 500;
void Initialization(void) {
    LATA = 0x00;
    LATB = 0X00;
    LATC = 0X00;
    LATD = 0X00;
    LATE = 0X00;
    TRISA = 0x00;
    TRISB = 0x00;
    TRISC = 0x00;
    TRISD = 0x00;
    TRISE = 0x00;
    PORTA = 0x00;
    PORTB = 0x00;
    PORTC = 0x00;
    PORTD = 0x00;
    PORTE = 0x00;
void delay(void) {
//inside-- is slower
//inside++ is faster
    for (inside = 0; inside > scanPin; inside++) {
         for (outside = 0; outside < temp; outside++) {
   //      for (inside = 0; inside < 5000; inside--) {
void main(void) {
    //unsigned char array[9] = {0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};
    while (1) {
        //    PORTB = offset--;
        PORTD = offset[0];//array[0];
        delay();
        PORTD = offset[1];//array[1];
        delay();
        PORTD = offset[2];//array[2];
        delay();
        PORTD = offset[3];//array[3];
        delay();
        PORTD = offset[4];//array[4];
        delay();
        PORTD = offset[5];//array[5];
        delay();
        PORTD = offset[6];//array[6];
        delay();
        PORTD = offset[7];//array[7];
        delay();
Dimebag
Postby Tom Maier » Sun Jul 20, 2014 2:49 pm
You need to get back to just blinking an LED or this will get out of hand. Ric suggested just using the built in __delay function that is in XC8, and that is a simple start.
Also, how are you seeing atmel parts as a compilation option?
Tom Maier
Postby Dimebag » Sun Jul 20, 2014 2:57 pm
hahaha, that's what the guy behind the sales counter tried to sell me. I was not impressed.
Dimebag
Postby Dimebag » Sun Jul 20, 2014 3:10 pm
I think I did do that. I am not sure if it would program to device that way. I am unable to show evidence. Please select a device in which I am able to provide code for Blinking led.
Dimebag
Postby Dimebag » Sun Jul 20, 2014 3:15 pm
If your going to select PIC24/PIC32. I will need the fuse configuration declarations. I will need a sample code as well to support.
Dimebag
Postby Tom Maier » Sun Jul 20, 2014 3:28 pm
You are being uncooperative, so I have to bail out here...
Tom Maier
Postby vloki » Sun Jul 20, 2014 8:48 pm
Tom Maier wrote:You are being uncooperative, so I have to bail out here...
+1 ;-)
Postby Dimebag » Mon Jul 21, 2014 8:23 am
Hi Tom, I am waiting for the store to order some PIC24's, PIC32's. I will be hooking up a micro over the weekend to test the LED blinking program. At the moment I am using Proteus VSM to simulate the programs. BTW I have started using the delay_ms().
Dimebag
