MPLAB C18
Re: MPLAB C18
Postby Dimebag » Sun Jul 06, 2014 12:30 pm
please explain the reference to first post.
In my personal experience it is MUCH more easy to use for beginners than classic MPLAB
Your personal experience. Explain it to me
We used this PIC years ago in our student labs on PICDEM 2+ boards.
Later we replaced them with 4520 because of internal oscillator and other improvements
In the meantime we switched again and are using 45K22 and 25K22 chips on our lab boards.
Please share your experience.
So you use MPLAB-X now ?
What hardware do you have ?
MCHP demo board ?
Debugger ?
Explain Please. I am sure that you are smarter than me, but explain yourself as you try to ask question outside my fields.
Dimebag
Re: MPLAB C18
Postby vloki » Sun Jul 06, 2014 12:39 pm
MPLAB-X is in my opinion much more easy than MPLAB because I had to coach
hundreds of students when they started and there definitely have been more issues
with MPLAB than with MPLAB-X
2. I think I do my very best to share my experience
3. The more I know the easier it is for me not to suggest some useless things ;-)
4. If you describe your equipment I could send you a working project within a minute ?
Re: MPLAB C18
Postby Dimebag » Sun Jul 06, 2014 12:59 pm
You have been very helpful, I however can't find the correct linker file needed for application using 18F452.The program uses 18F452...I can not find the LKR files, can you help with this please?
Dimebag
Re: MPLAB C18
Postby vloki » Sun Jul 06, 2014 1:12 pm
Actual versions of IDE find and add the correct linker file automatically !
(I don't think it makes sense to learn how to use outdated equipment)
((( linker files may be located in bin/lkr folder of the compilers installation folder )))
Re: MPLAB C18
Postby vloki » Sun Jul 06, 2014 1:21 pm
Just to make sure that you have seen this :roll:
vloki wrote:I think you need to read the C18 compiler readme
MPLINK™ Linker and MPLAB IDE COFF File Format
Due to a change in COFF file format, MPLAB C18 v3.00 and later will not be compatible with versions of MPLINK Linker prior to v4.00 or versions of the MPLAB IDE prior to v7.21
getting started with MPLABX
Re: MPLAB C18
Postby Dimebag » Sun Jul 06, 2014 1:39 pm
Yes, at last you lost me again...Thanks world. If a person can't ask why? Seems to be the answer...How do I phase my question here. I ask and don't really understand the answers. WTH am I doing wrong if the complier isn't working the way I think it should. Back to the "ReadMe" grr
Dimebag
Re: MPLAB C18
Postby vloki » Sun Jul 06, 2014 1:45 pm
Dimebag wrote:How do I phase my question here. I ask and don't really understand the answers.
If this is your problem -> How to ask questions ;-)
Re: MPLAB C18
Postby ric » Sun Jul 06, 2014 2:01 pm
Dimebag wrote:...
My first time in C18. I have MPLAB 7.20 installed. Some ideas what I need to do to fix this failure please.
I would recommend updating to MPLAB 8.92.
It still looks much the same as MPLAB 7.20 (not like the total shift you find with MPLABX), but without those incompatibilities. Version 7.20 is ancient (i.e. about 2005 vintage).
You can download any version of MPLAB from http://www.microchip.com/pagehandler/en ... parts.html
Re: MPLAB C18
Postby Dimebag » Sun Jul 06, 2014 2:11 pm
In your opinion. Show me examples of MPLAB vs MPLAB-X. You said "definitely" ....more issues. Explain the issues your students encountered?
Dimebag
Re: MPLAB C18
Postby ric » Sun Jul 06, 2014 2:16 pm
There's no need to be so aggressive to someone who's trying to help you.
