[URGENT]UART Bootloader and Application
Postby vibhu » Tue Jul 16, 2019 2:37 pm
Hi Guys,
I have a query regarding UART boot loader application.
I am using a UART bootloader application which is given by MPLAB Harmony.. And I have an application.
I have attached the application in the loadables section of the bootloader.
I copied the same configuration bits settings for both the bootloader and the application.
But it is still giving an error
(944) data conflict at address 1FC005F0h.
Please Help.
I am attaching the linker file of both the bootloader and the application.
I am using PIC32mz1024EFE100 chip.
Vibhu.
btl_mz.txt.txt
linker file of the bootloader
(71.85 KiB) Downloaded 950 times
app_mz.txt.txt
linker file of application
(71.98 KiB) Downloaded 941 times
vibhu
Re: UART Bootloader and Application
Postby vibhu » Tue Jul 16, 2019 2:59 pm
When I am trying to build the application code separately its giving
Configuration Bits: address 0x1FC0FFC4: FPLLRNG = 7 does not match any valid value in the device database.
Setting to the default value.
Configuration Bits: address 0x1FC0FFC8: DMTCNT = 31 does not match any valid value in the device database.
Loading completed
So, does that mean the application is still taking the configuration bits ?
I have commented out the configuration bits part i system_init.c
vibhu
Return to PIC32 topics
