Need a PIC Decompiler for PIC 12F1822
Postby stevie72 » Tue Apr 23, 2019 5:31 pm
Hello Friends,
I need a Decompiler to get the Source Code back from a HEX File (3Kb)
Is there a way to Decompile /Disassemle the hex file?
Any Suggestions ?
Greethings, Stefan
stevie72
Re: Need a PIC Decompiler for PIC 12F1822
Postby KTrenholm » Tue Apr 23, 2019 9:12 pm
Retrieving the code written to compile/assembly the hex file I think is an impossibility with only the binary hex file to go on.
However you CAN import the hex file into MPLAB X and see the code in the program memory:
Program Memory.JPG (66.41 KiB) Viewed 16393 times
To do this, in MPLAB X, File > Import > Hex/ELF (Prebuilt File)
This will import the hex file into a new project. From there, Window > Target Memory Views > Program Memory
KTrenholm
