I am new, and need help
Postby elZero » Sat Aug 04, 2018 2:10 pm
I am new to microcontrollers and programming for embedded systems. Just got a gift of a PICKit3 and decided to test it out. The ode compiles, but the microcontroller doesn't do what I expected it to do(count from 1-31, in binary and output it to connected LEDs. There is an external 6MHz Crystal Oscillator, and the MCLR pin is pulled high through a 10K resistor.
Here's the code:
#pragma config FOSC = HS
#pragma config WDTE = OFF
#pragma config PWRTE = OFF
#pragma config MCLRE = ON
#pragma config BOREN = OFF
#pragma config LVP = OFF
#pragma config CPD = OFF
#pragma config CP = OFF
#define _XTAL_FREQ 6000000
void main(void)
    TRISA = 0xE0;
    unsigned char i;
    i = 0;
    for(i = 0; i <= 31; i++)
        PORTA = i;
        __delay_ms(100);
        if(i=31)i=0;
Reason: Added "code" tags around the code.
elZero
Re: I am new, and need help
Postby Jorgef » Sun Aug 05, 2018 5:03 am
Hi
I just saw that you are already receving replies in the MCHP forum.
if I can add something, just ask.
Best regards
Jorge
Jorgef
Postby ric » Sun Aug 05, 2018 10:23 am
Appears to be cross posted from: https://www.microchip.com/forums/m1063072.aspx
Over there it has been revealed that the PIC is a PIC16F628A
Also the bug in " if(i=31)i=0;" which should be "==" has been noted.
Postby ric » Sun Aug 05, 2018 12:52 pm
Here it is with the config bits taken from the MPLABX config editor, and the main loop done in a more standard way
// PIC16F628A Configuration Bit Settings
// CONFIG
#pragma config FOSC = HS        // Oscillator Selection bits (HS oscillator: High-speed crystal/resonator on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN)
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = OFF      // Power-up Timer Enable bit (PWRT disabled)
#pragma config MCLRE = ON       // RA5/MCLR/VPP Pin Function Select bit (RA5/MCLR/VPP pin function is MCLR)
#pragma config BOREN = OFF      // Brown-out Detect Enable bit (BOD disabled)
#pragma config LVP = OFF        // Low-Voltage Programming Enable bit (RB4/PGM pin has digital I/O function, HV on MCLR must be used for programming)
#pragma config CPD = OFF        // Data EE Memory Code Protection bit (Data memory code protection off)
#pragma config CP = OFF         // Flash Program Memory Code Protection bit (Code protection off)
void main(void)
    unsigned char i;
    TRISA = 0b11100000;    // RA0-4 all output
    while (1)
            PORTA = i;
            __delay_ms(100);
