#ifndef _HARDWARE_PROFILE_H_
#define _HARDWARE_PROFILE_H_
// Define your clock speed here
// Sample clock speed for a 16-bit processor
#if defined (__C30__)
// Various clock values
#define GetSystemClock() 32000000UL
#define GetPeripheralClock() (GetSystemClock())
#define GetInstructionClock() (GetSystemClock() / 2)
// Clock values
#define MILLISECONDS_PER_TICK 10
#define TIMER_PRESCALER TIMER_PRESCALER_8 // 8MHz: TIMER_PRESCALER_1
#define TIMER_PERIOD 20000 // 10ms=20000, 1ms=2000
#elif defined( __PIC32MX__)
#define USB_A0_SILICON_WORK_AROUND
//#define RUN_AT_48MHZ
//#define RUN_AT_24MHZ
#define RUN_AT_60MHZ
#if defined(RUN_AT_48MHZ)
#define GetSystemClock() 48000000UL
#define GetPeripheralClock() 48000000UL
#define GetInstructionClock() (GetSystemClock() / 2) ???
#elif defined(RUN_AT_24MHZ)
#define GetSystemClock() 24000000UL
#define GetPeripheralClock() 24000000UL
#elif defined(RUN_AT_60MHZ)
#define GetSystemClock() 60000000UL
#define GetPeripheralClock() 60000000UL // Will be divided down
#else
#error Choose a speed
#endif
// Clock values
#define MILLISECONDS_PER_TICK 10 // -0.000% error
#define TIMER_PRESCALER TIMER_PRESCALER_8 // At 60MHz
#define TIMER_PERIOD 37500 // At 60MHz
#endif
//#define USE_USB_PLL
#if defined(__PIC32MX__)
#endif
// Define the baud rate constants
#if defined(__C30__)
#define BAUDRATE2 9600UL
#define BRG_DIV2 4
#define BRGH2 1
#elif defined (__PIC32MX__)
#define BAUDRATE2 57600UL
#define BRG_DIV2 4
#define BRGH2 1
#endif
#if defined(__PIC24F__)
#include <p24fxxxx.h>
#include <uart2.h>
#elif defined(__PIC24H__)
#include <p24hxxxx.h>
#include <uart2.h>
#else
#include <p32xxxx.h>
#include <plib.h>
#include <uart2.h>
#endif
// Select your MDD File System interface type
// This library currently only supports a single physical interface layer
//#define USE_SD_INTERFACE_WITH_SPI // SD-SPI.c and .h
//#define USE_CF_INTERFACE_WITH_PMP // CF-PMP.c and .h
//#define USE_MANUAL_CF_INTERFACE // CF-Bit transaction.c and .h
#define USE_USB_INTERFACE // USB host MSD library
/** TRIS ***********************************************************/
#define INPUT_PIN 1
#define OUTPUT_PIN 0
#endif
Function:
void InitializeClock( void )
Description:
This function initializes the tick timer. It configures and starts the
timer, and enables the timer interrupt. We are using Timer 3 so we can
also trigger an A/D conversion when the timer rolls over.
Precondition:
None
Parameters:
None
Returns:
None
Remarks:
None
currentTick = 0;
IPC2bits.T3IP = TIMER_INTERRUPT_PRIORITY;
IFS0bits.T3IF = 0;
TMR3 = 0;
PR3 = TIMER_PERIOD;
T3CON = TIMER_ON | STOP_TIMER_IN_IDLE_MODE | TIMER_SOURCE_INTERNAL |
GATED_TIME_DISABLED | TIMER_16BIT_MODE | TIMER_PRESCALER;
IEC0bits.T3IE = 1;
return;
Function:
void InitializeAnalogMonitor( void )
Description:
This function initializes the monitoring of the three analog inputs.
Since we need to monitor Vbus while doing other operations, we will
simply scan all required input channels: the temperature sensor (AN4),
the potentiometer (AN5), and Vbus (AN8).
Precondition:
None
Parameters:
None
Returns:
None
Remarks:
None
// Set up the A/D converter
AD1PCFGL = ~SCAN_MASK; // Disable digital input on AN4, AN5, AN8
AD1CSSL = SCAN_MASK; // Scan AN4, AN5, AN8
AD1CON3 = 0x1F05; // 0001 1111 0000 0101; 31 Tad auto-sample, Tad = 5*Tcy
#ifdef VERSION_INSTRUMENT_5200G
AD1CON2 = 0x240C; // 0010 0100 0000 1100; Scan inputs, 3 conversions per interrupt, MUX A only
#endif
AD1CON1 = 0x8046; // 1000 0000 0100 0110 ; Turn on, start sampling, convert on Timer 3
// Enable A/D interrupts
IEC0bits.AD1IE = 1;
return;
char ZeroSetting(void)
// FILTEROUT=TRUE;
Zeroing=FALSE;
ReadingCount=0;
CumZero1=0;
CumZero2=0;
VectorFlag=0;
// ZEROINPUT = TRUE;
// LongDelay(4);
PR3=1250; //Corresponds to 50Hzx256 so expected time = 3.125secs.
Zeroing=TRUE;
do {}while (Zeroing==TRUE);
// ZEROINPUT = FALSE;
return 1;
Function:
void __attribute__((__interrupt__, auto_psv)) _T5Interrupt(void)
Description:
Timer 5 Interrupt occurs upon static condition,
when PR corresponding to 200 RPM (PR4,5) are matched.
Thus this int occurs if speed is below 200RPM
Refeed PR4/5 in InitializeTimers() to change it.
Precondition:
None
Parameters:
None
Return Values:
None
Remarks:
None
void __attribute__((__interrupt__, auto_psv)) _T5Interrupt( void )
if (IFS1bits.T5IF)
// Clear the interrupt flag
IFS1bits.T5IF = 0;
OverflowFlag = TRUE;
Error3 = TRUE;
SyncFlag = 0;
Function:
void __attribute__((__interrupt__, auto_psv)) _INT0Interrupt(void)
Description:
Timer ISR, used to update the tick count. Since we are using Timer 3, we
can also trigger an A/D conversion off of the timer.
Precondition:
None
Parameters:
None
Return Values:
None
Remarks:
None
void __attribute__((__interrupt__, auto_psv)) _INT0Interrupt( void )
if (IFS0bits.INT0IF)
IFS0bits.INT0IF = FALSE; // Clear the interrupt flag
//If it comes here then no overflow if speed >200:
//This divides the T3 time period by 256 to run ADC interrupt via T3
TimerLoCount=TMR4; //first read Lo count
TimerHiCount=TMR5HLD; //stick the TMR5 held value
PeriodCountNew=(TimerHiCount*65536+TimerLoCount); //while the period is computed.
CountLoLimit=0.98*PeriodCountNew; //+/- 2% deviation permitted so limits are computed
CountHiLimit=1.02*PeriodCountNew;
PR3=PeriodCountNew/NoSteps; //PR3 is loaded to generate steps for A/D
StepCount=0; //Step counter is zeroed on each interrupt.
CycleCount++; //Cycle count is inc.
if (CycleCount==NoOfCycles)
{VectorFlag=0; //completed 32 cycles averaging.
OverflowFlag=0;
if ((PeriodCountOld>=CountLoLimit)&(PeriodCountOld<=CountHiLimit))
SyncFlag=1; //Sync status is determined with this
else {SyncFlag=0;}
PeriodCountOld=PeriodCountNew; //Latest reading becomes older one before returning. Stays till the next int. Used for RPM computation in UpdateRPM()
TMR4=0; //reset the timers //and the timer 4/5 is reset to zero to start the next cycle count.
TMR5=0;
Function:
void __attribute__((__interrupt__, auto_psv)) _T3Interrupt(void)
Description:
Trigger of an A/D conversion off of the timer. PR varies as per T4/5 count
void __attribute__((__interrupt__, auto_psv)) _T3Interrupt( void )
if (IFS0bits.T3IF)
IFS0bits.T3IF = 0;
PR3=1000;
STEPWAVE = STEPFLG; //generates 128x frequency for filter on RA7.
STEPFLG = !STEPFLG;
StepCount++;
if (StepCount>=NoSteps){StepCount=0;}
//to check the output waveform: Change to a port pin.
Function:
void __attribute__((__interrupt__, auto_psv)) _T2Interrupt(void)
Description:
Timer ISR, used to update the tick count as also the Keyboard scan
Precondition:
None
Parameters:
None
Return Values:
None
Remarks:
None
void __attribute__((__interrupt__, auto_psv)) _T2Interrupt( void )
if (IFS0bits.T2IF)
IFS0bits.T2IF = 0;
currentTick++;
Update_KBD();
Function: void __attribute__((__interrupt__, auto_psv)) _DefaultInterrupt(void)
This is just here to catch any interrupts that we see during debugging.
void __attribute__((interrupt, auto_psv)) _DefaultInterrupt(void)
// UART2PrintString( "!!! Default interrupt handler !!!\r\n" );
while (1)
Nop();
Nop();
Nop();
void __attribute__((interrupt, auto_psv)) _OscillatorFail(void)
// UART2PrintString( "!!! Oscillator Fail interrupt handler !!!\r\n" );
while (1)
Nop();
Nop();
Nop();
void __attribute__((interrupt, auto_psv)) _AddressError(void)
// UART2PrintString( "!!! Address Error interrupt handler !!!\r\n" );
while (1)
Nop();
Nop();
Nop();
} void FrequencyScan(void)
TRISA=(TRISA&0b1111111101111111);
T2CON = 0x00; //Stops the Timer1 and reset control reg.
TMR2 =0x00; //Clear contents of the timer register
PR2 = 500;
//IPC0bits.T2IP = 0x02; //Setup Timer1 interrupt for desired priority level
// (This example assigns level 1 priority)
IFS0bits.T2IF = 0; //Clear the Timer1 interrupt status flag
IEC0bits.T2IE = 1; //Enable Timer1 interrupts
T2CONbits.TON = 1; //Start Timer1 with prescaler settings at 1:1 and
T2CONbits.TCKPS = 0b00;
DispFirstLine(0);
Put_String_LCD(" ok ");
DispSecLine(0);
Put_String_LCD(" running ");
if (KEY_PRESSED == S2)
KEY_PRESSED=0;
mainstate = OPENING_SCREEN;
return;
KEY_PRESSED=0;
// Interrupt Service Routine code goes here
IFS0bits.T1IF = 0; //Reset Timer1 interrupt flag and Return from ISR
STEPWAVE=STEPFLG;
STEPFLG=!STEPFLG;
}Users browsing this forum: No registered users and 2 guests
