Not An Interrupt to be Seen
Postby SLTom992 » Tue Jun 10, 2014 9:03 pm
Here is the initialization procedure I've followed as shown the manual for the PIC18F45K22:
Timer3 is initialized to run wide open on the 4 MHz system clock/4 = 1 uSec per count.
TMR3H = 0; // Clear high byte
TMR3L = 0; // Clear low byte
clrbit(PIR2, TMR3IF); // Clr TMR3 int flag
setbit(PIE2, TMR3IE); // Set timer 3 interrupt enable
setbit(T3CON, TMR3ON); // Set timer 3 running
setbit(INTCON, PEIE); // Set peripheral device interrupt enable
setbit(INTCON, GIE); // Set Global Interrupt Enable
di();
TMR3H = 0xFF; // SET high timer for 125 usec
TMR3L = 0x83; // FF83 == 125 uSec to rollover
ei();
The timer is running but there is no interrupt produced on the tick over from FFFF to 0000.
Can anyone suggest what the heck I'm doing wrong?
SLTom992
Re: Not An Interrupt to be Seen
Postby jtemples » Tue Jun 10, 2014 9:25 pm
How are you determining there's no interrupt?
We can't know if things like "setbit" are doing what they're supposed to; better to explicitly initialize the registers.
Postby SLTom992 » Tue Jun 10, 2014 9:44 pm
I set a breakpoint in the interrupt procedures.
I was setting all of the bits in each register explicitly and when that didn't work I reverted to the set or clr bit functions as per the manual suggestions.
In case it wasn't defaulting everywhere to high priority I explicitly set RCON register with IPEN high and OPR2 with TMR3IP set high. No change.
I have stopped the program and checked the TMR3H & L and they are indeed running.
SLTom992
Postby jtemples » Tue Jun 10, 2014 9:52 pm
Did you look at TMR3IF to see if it's set? If it is, are GIE, PEIE, and TMR3IE all set as well?
Postby SLTom992 » Tue Jun 10, 2014 10:38 pm
You appear to be correct - directly after I set INTCON to 0xC0 it reads out 0x06 what do you suppose would cause that?
SLTom992
Postby jtemples » Tue Jun 10, 2014 10:54 pm
Post the complete test program (setting the registers directly) that shows the problem. What compiler are you using?
Postby SLTom992 » Tue Jun 10, 2014 10:58 pm
I am using XC-8 Free Version at the moment.
OK, in order to check everything out I set everything explicitly and then set breakpoints and checked the bits set and not.
Everything was OK except for INTCON
T3CON = 0;
PIR2 = 0b00000000; // Clear TMR2IF
IPR2 = 0b00000010; // Set TMR3IP
PIE2 = 0b00000010; // Set TMR3IE
INTCON = 0xC0; // 0b11000000 GIE and PEIE
T3CON = 0b00000001; // TMR3ON
When I set the breakpoint on TMR3H and checked INTCON it was 0x06 instead of 0xC0.
I get the feeling that this has something to do with the CONFIG but certainly can't find anything there that appears to have anything to do with this.
SLTom992
Postby jtemples » Tue Jun 10, 2014 11:26 pm
You've enabled interrupts before assigning to TMR3H, so you're probably vectoring. That's why I asked for a complete program.
Postby SLTom992 » Tue Jun 10, 2014 11:53 pm
It said in the manual that you specifically had to zero the counter registers before enabling the interrupts. But apparently the EXACT order of the sets has to be necessary.
I now moved this initialization of the timer to the area directly below the port assignments and put it in the following order:
    INTCON = 0b11000000;
    timer3_countL = 8;              // 1 millisecond timeout (in ISR)
    PIR2 = 0b00000000;
    RCON = 0b10000000;
    T3CON = 0;
    IPR2 = 0b00000010;
    PIE2 = 0b00000010;
    T3CON = 0b00000001;
And while it appears that I have some sort of timing calculation off somewhere it is working somewhat and the timer IS giving an interrupt.
I would like to thank you for all of your help.
Originally I set the interrupt initialization up exactly as it was written in the manual and it didn't mention that when you're initializing several interrupts you have to do it in a specific order. Interesting.
Reason: added code tags
SLTom992
Postby ric » Wed Jun 11, 2014 12:46 am
I would make
the very last statement in your initialisation code. You don't want any interrupts to occur until you have finished all the initialisation.
Next
Users browsing this forum: Baidu [Spider] and 7 guests
