Shortest way to calculate parity on a PIC16F
Postby ric » Sun Jun 01, 2014 11:24 am
Ultimate code to calculate parity on a mid-range PIC (which cannot test bits of the W register directly)
Pass the value to be checked in a file register (shown as "X" below). This register is NOT modified.
Will return NZ (and 0x80 in W) if the parity is odd, else returns Z and 0x00 in W
CheckParity:
        swapf   X, w    ; John's idea: reducing byte to nibble
        xorwf   X, w    ;   "     "       "       "   "   "
        addlw   41H     ; bit 1 becomes B0^B1 and bit 7 becomes B6^B7
        iorlw   7CH     ; for carry propagation from bit 1 to bit 7
        addlw   2       ; Done! the parity bit is bit 7 of W
        andlw   80H     ; set NZ if odd parity, and leave 00 or 80 in W
        return
Note, enhanced mid range chips (PIC16F1xxx) and also PIC18F chips can test bit 7 of W directly, so the final instruction is not necessary.
The following macro produces pretty similar code in Hitech C.
#define PARITY(b)   ((((((b)^(((b)<<4)|((b)>>4)))+0x41)|0x7C)+2)&0x80)
This came from original discussions at http://www.microchip.com/forums/m4732.aspx
and http://www.microchip.com/forums/m4738.aspx and http://www.microchip.com/forums/m4762.aspx
Return to Tips and Tricks
