Serial communication RS-485 between Pic16F690/PIC16F18877
Re: Serial communication RS-485 between Pic16F690/PIC16F1887
Postby ciclingman » Tue Feb 10, 2026 12:42 pm
Good morning Susan. Last weekend I solved my communication problem, discovering that there were 2 settings to do that I didn't read in the datasheet and that you didn't recommend:
The first approach is this:
RC6PPS = 0x10;
The second setting is the setting of the communication pines as entrances.
I was wrong because I set the TX as output, RX as input exactly as I did with the PIC16F690. The rest of the program is always the same.
ciclingman
Postby ciclingman » Mon Mar 09, 2026 8:50 pm
Good morning. I realized that the PIC16F18877 does not transmit, but only receives. I don't understand what's wrong with the settings I've written in previous posts. Can someone please help me?
ciclingman
Postby AussieSusan » Tue Mar 10, 2026 2:23 am
Try asking this on the main Microchip forum, giving a full listing of the code you have now.
There are many more people with a lot of experience there.
Postby ciclingman » Tue Mar 10, 2026 7:22 am
If you are able to answer my question ok, otherwise I invite you to ignore my questions, thanks. I did not despise your help, on the contrary you were fundamental. I only wrote that that program string, you had not mentioned it to me.
ciclingman
Postby ric » Tue Mar 17, 2026 11:16 am
You seem to be reacting badly to a perfectly sensible suggestion.
Return to SCI/USART/EUSART
Users browsing this forum: No registered users and 11 guests
