4/8bit LCD library for HD44780, HD47780, ST7036 TestProject
Postby vloki » Wed Apr 29, 2015 10:49 am
MPLAB-X project with differnt configurations for testing LCD lib
on different boards and with different PICs and compilers.
- PICDEM 2+, PIC18F4520, XC8
- PICDEM USB, PIC18F4550, C18
- custom board, PIC18F25K22, C18 + XC8
(? http://www.microchip.com/forums/FindPost/860680 )
<edit> added 8bit data support ...
LCD_LIB_TEST_20150608.zip
(16.14 KiB) Downloaded 700 times
Re: 4/8bit LCD library for HD44780, HD47780, ST7036 TestPro
Postby RodneyBoris » Sun Jul 15, 2018 12:59 pm
vloki wrote:MPLAB-X project with differnt configurations for testing LCD lib
on different review boards of phenq and with different PICs and compilers.
Thank you SO much for adding 8bit data support. Needed it badly for a project and was stuck. I really appreciate your efforts.
RodneyBoris
Postby ric » Tue Jul 31, 2018 4:33 am
In LCD_LIB_BUSY.H
// Cursor / Display shift       0   0   |   0   0   0   1   S/C R/L -   -
    #define DISPLAY_SHIFT_R     0x1C
    #define DISPLAY_SHIFT_L     0x18
    #define CURSOR_MOVE_R       0x14
    #define CURSOR_MOVE_L       0x14
The last line should be 0x10, not 0x14
Postby vloki » Wed Aug 01, 2018 7:28 am
Oh, yes.
My git repository tells me that I corrected that in November 2015.
Guess it was never used until now ;-)
There is at least one more thing that should be corrected.
In the same header a delay after the Clear display macro was added;
void LCD_Init(void);
#define LCD_Clear() LCD_Command(CLEAR_DISPLAY); LCD_DELAY_5MS()
#define LCD_Home()  LCD_Command(RETURN_HOME); LCD_DELAY_5MS()
I should rebuild the test project with actual sources and post it here...
Return to Graphics and LCD
