I am new to self programming of PIC24. Basically I have SIM900D modem and my application is fully working I can send receive data with server.
Now I want to implement OTA upgrade for PIC24. For that I need to write a dedicated routine called bootloader with all SIM900D functions.
So here is my flow for that please correct me if I am wrong at any place.
I will store this dedicated routine at some starting location and allocate some flash for that, My Application code will store afterward locations and I have a dedicated Serial flash where I can store the incoming firmware.
Now my question is when I receive the new firmware(hex file) by SIM900D do I need to simply write that file from Application start location? Or I have to skip any part from hex which is actually not required to overwrite?
Configuration word is also going to be received in Hex file correct? Do I need to update them also or it is OK to leave them as it will be same in both that dedicated bootloader with GSM functions?
