Device configuration
Re: Device configuration
Postby Dimebag » Sun Jul 20, 2014 11:40 am
void delay(void) {
//inside-- is slower
//inside++ is faster
    for (inside = 0; inside > scanPin; inside++) {
         for (outside = 0; outside < temp; outside++) {
   //      for (inside = 0; inside < 5000; inside--) {
Dimebag
Postby ric » Sun Jul 20, 2014 11:51 am
Rolling your own time delays can be tricky.
Please remind me which compiler you are using.
Postby Dimebag » Sun Jul 20, 2014 11:58 am
ok
Dimebag
Postby ric » Sun Jul 20, 2014 12:05 pm
XC8 has an accurate time delay function built in. Look in the user guide for
__delay_ms()
Postby Dimebag » Sun Jul 20, 2014 12:22 pm
I am looking at devices within PIC24 and PIC32 to use. I just need help with C in the mean while.
Dimebag
Postby Dimebag » Sun Jul 20, 2014 12:40 pm
More interested in PIC24 currently. I will start on PIC32. Currently my local electronic store does not have PIC24 :(
Dimebag
Postby Dimebag » Sun Jul 20, 2014 12:41 pm
In the meantime 18F452 is selected as target device. Funny they have ATmega/12F-C/16F/18F/18LF
Dimebag
Postby Dimebag » Sun Jul 20, 2014 1:12 pm
Thanks ric, I will look at using the function delay_ms().
I am wondering if using "array[]" is the best way for expanding my code, it is working at bare minimum. An array can only have values stored inside the "array[]" to be used after its complied. I am not sure if you can change the 'array[]' values after its complied.
Dimebag
Postby ric » Sun Jul 20, 2014 1:28 pm
Yes, you can change array values after compilation, so long as you haven't specifically told the compiler it is a constant.
Postby Tom Maier » Sun Jul 20, 2014 1:43 pm
Dimebag wrote:In the meantime 18F452 is selected as target device. Funny they have ATmega/12F-C/16F/18F/18LF
Dimebag,
What tools are you using? You shouldn't see ATmega if you are using XC8.
Also do you have a programmer? If so, which one?
You need to get back to just writing a program that blinks an LED. You are getting sidetracked onto other subjects.
Tom Maier
