MPLAB C18
Re: MPLAB C18
Postby Dimebag » Sun Jul 06, 2014 2:19 pm
Not intended.
Dimebag
Re: MPLAB C18
Postby Dimebag » Sun Jul 06, 2014 2:29 pm
I will see if I can find the rev 8.xx that is needed. thank you Ric.
Dimebag
Re: MPLAB C18
Postby ric » Sun Jul 06, 2014 2:36 pm
8.92 is right there on the page I linked to.
Re: MPLAB C18
Postby Dimebag » Sun Jul 06, 2014 2:40 pm
I am trying to get to entry level Robotic engineering. Field for Enhanced Biology & electronics engineering.
Dimebag
Re: MPLAB C18
Postby jtemples » Sun Jul 06, 2014 5:31 pm
Dimebag wrote:I however can't find the correct linker file needed for application using 18F452.
In a typical application, you don't need to worry about linker files; the linker will find the right file automatically.
Re: MPLAB C18
Postby vloki » Sun Jul 06, 2014 5:53 pm
Dimebag wrote:I am trying to get to entry level Robotic engineering. Field for Enhanced Biology & electronics engineering.
What time was it in Australia when you posted this ?
Australians never sleep ric ?
Re: MPLAB C18
Postby ric » Sun Jul 06, 2014 9:24 pm
11:40pm in Sydney.
Early evening for a student ;)
Re: MPLAB C18
Postby Tom Maier » Sun Jul 06, 2014 10:39 pm
Dimebag,
It would be wise to go with the latest develpment software since you are just starting out. The mplab and C18 are a dead end. Get the mplabx and the xc8 compiler. That's the future.
People still use mplab and c18 because they used it for many years and haven't migrated over yet. If you start with the obsolete software, you will also have to go through the migration pain, but for no reason.
Tom Maier
Re: MPLAB C18
Postby Ian.M » Mon Jul 07, 2014 3:32 am
OTOH if you need to check existing C18 code that you have found works before converting it to XC8, you need it installed and there is more C18 code out there than HiTech or XC8 PIC18 code. C18 is usable, but its sucky, frequently non-ANSI compliant and frequently makes your life more difficult than it needs to be. *DONT* start new projects in C18, but *DO* have both installed.
Re: MPLAB C18
Postby Dimebag » Mon Jul 07, 2014 12:19 pm
I have installed the XC2 complier. I would like to thank Tom for the very helpful comments he has made. I would also like to thank all of you for your guidance. I will take a couple of weeks to read over the notes and start some simple programs.
Dimebag
