PIC17C42A to PIC17C44
Postby perdrix » Wed Nov 24, 2021 1:34 pm
I have some code for the PIC17C42A, but I can't get them right now or for the foreseeable future.
I have managed to get some PIC17C44 parts.
I thought that code for PIC17C42A should run unchanged on the PIC17C44.
I re-compiled the code for PIC17C44 changing:
   list   p=17c42a
   include   <P17c42a.inc>
to
   list   p=17c44
   include   <P17c44.inc>
and the output hex file was identical.
However when I programmed a 17C44 it didn't work :( It's possible of course that the chip was bad, but I'm loath to burn more of these OTP parts as I only have a limited stock.
I've spent a long time looking at the datasheet and don't understand why it didn't, because unless I missed something the pin-out is identical. Are there some crucial parts of the memory map (e.g. interrupt vectors) that are different?
Can someone who knows these parts better than I give me some guidance.
perdrix
Re: PIC17C42A to PIC17C44
Postby perdrix » Thu Nov 25, 2021 3:31 pm
It was a simple error - I needed to set the config bits!!! Now works fine!
perdrix
Postby ric » Thu Nov 25, 2021 8:50 pm
Well done to track it down yourself.
Plainly this is related to the discussion at https://www.microchip.com/forums/m1192298.aspx
Postby perdrix » Thu Nov 25, 2021 9:06 pm
Yes, absolutely correct :)
David
perdrix
