S/W: MPLABX, XC8
4MHz Xtal
Untill my newer PIC16F18877's turn up, I'm using this chip. But with the help of some tweaked example code I'm trying to find my way around a GLCD.
Example code from https://www.exploreembedded.com/wiki/Interfacing_GLCD(128x64)_with_PIC16F877A
Here's the code I'm using..
* File: main.c
* Author: Example Code from exploreembedded.com
* Created on 09 January 2021, 23:37
// CONFIG
#pragma config FOSC = XT // Oscillator Selection bits (XT oscillator)
#pragma config WDTE = OFF // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config CP = OFF // FLASH Program Memory Code Protection bits (Code protection off)
#pragma config BOREN = ON // Brown-out Reset Enable bit (BOR enabled)
#pragma config LVP = OFF // Low Voltage In-Circuit Serial Programming Enable bit (RB3 is digital I/O, HV on MCLR must be used for programming)
#pragma config CPD = OFF // Data EE Memory Code Protection (Code Protection off)
#pragma config WRT = ON // FLASH Program Memory Write Enable (Unprotected program memory may be written to by EECON control)
#include <pic.h>
#include <pic16f877.h>
#include <htc.h>
#include <stdio.h>
* Project name: Testing GLCD with PIC16F887
#define FOSC = 4000000L
* Control bus PB0:PB4
* Data bus PD0:PD7
#define GlcdDataBus PORTD
#define GlcdControlBus PORTB
#define GlcdDataBusDirnReg TRISD
#define GlcdCtrlBusDirnReg TRISB
#define CS1 0x00 // Select segments 1-64
#define CS2 0x01 // Select segments 65-128
#define RS 0x02 // H: Data - L: Instruction
#define RW 0x03 // H: Read Data - L: Write Data
#define EN 0x04 // Enable
/* 5x7 Font including 1 space to display HELLO WORLD */
char H[]={0x7F, 0x08, 0x08, 0x08, 0x7F, 0x00};
char E[]={0x7F, 0x49, 0x49, 0x49, 0x41, 0x00};
char L[]={0x7F, 0x40, 0x40, 0x40, 0x40, 0x00};
char O[]={0x3E, 0x41, 0x41, 0x41, 0x3E, 0x00};
char W[]={0x3F, 0x40, 0x38, 0x40, 0x3F, 0x00};
char R[]={0x7F, 0x09, 0x19, 0x29, 0x46, 0x00};
char D[]={0x7F, 0x41, 0x41, 0x22, 0x1C, 0x00};
/* local function to generate delay */
void delay(int cnt)
int i;
for(i=0;i<cnt;i++);
void Glcd_SelectPage0() // CS1=1, CS2=0
GlcdControlBus |= (1<<CS1);
GlcdControlBus &= ~(1<<CS2);
void Glcd_SelectPage1() // CS1=0, CS1=1
GlcdControlBus &= ~(1<<CS1);
GlcdControlBus |= (1<<CS2);
/* Function to send the command to LCD */
void Glcd_CmdWrite(char cmd)
GlcdDataBus = cmd; //Send the Command nibble
GlcdControlBus &= ~(1<<RS); // Send LOW pulse on RS pin for selecting Command register
GlcdControlBus &= ~(1<<RW); // Send LOW pulse on RW pin for Write operation
GlcdControlBus |= (1<<EN); // Generate a High-to-low pulse on EN pin
delay(100);
GlcdControlBus &= ~(1<<EN);
delay(1000);
/* Function to send the Data to LCD */
void Glcd_DataWrite(char dat)
GlcdDataBus = dat; //Send the data on DataBus nibble
GlcdControlBus |= (1<<RS); // Send HIGH pulse on RS pin for selecting data register
delay(100);
delay(1000);
void Glcd_DisplayChar(char *ptr_array)
int i;
for(i=0;i<6;i++) // 5x7 font, 5 chars + 1 blank space
Glcd_DataWrite(ptr_array[i]);
int main()
GlcdDataBusDirnReg = 0x00; // Configure all the LCD pins as output
GlcdCtrlBusDirnReg = 0x00; // Configure the Ctrl pins as output
/* Select the Page0/Page1 and Turn on the GLCD */
Glcd_SelectPage0(); //
Glcd_CmdWrite(0x3F); //
Glcd_SelectPage1(); //
delay(100);
/* Select the Page0/Page1 and Enable the GLCD */
Glcd_CmdWrite(0xC0); //
delay(100);
Glcd_SelectPage0(); // Display HELLO on Page0, Line1
Glcd_CmdWrite(0xB8); // 0xB8 = line 0 (the top line)
Glcd_DisplayChar(H);
Glcd_DisplayChar(E);
Glcd_DisplayChar(L);
Glcd_DisplayChar(O);
Glcd_SelectPage1(); // Display WORLD on Page1, Last line
Glcd_CmdWrite(0xBF); // 0xB8 = line 7 (the bottom line)
Glcd_DisplayChar(W);
Glcd_DisplayChar(R);
Glcd_DisplayChar(D);
while(1);
... and here's the output on the analyser.
Problem is that there is no output on the screen, pixels are illuminated and contrast is adjustable.
Any suggestions would be appreciated
Regards
GB
