User Guide lists the 32khz clock as one of four oscillator options.
For the 16F84A what oscillator word should we use in config line?
Thanks!
EDIT Here is the text from manual.
A.6 OSCILLATOR OPTIONS
RC oscillator (2 MHz approximately) supplied. This oscillator may be disabled by
removing jumper J7.
Pads provided for user-furnished crystal and two capacitors.
Removable, 4 MHz, canned oscillator.
32.768 kHz (watch-type) crystal for Timer1.
Looks like you disable by jumper the 2MHZ RC oscillator then remove the 4MHZ canned oscillator.
Then hope Microchip routes the 32khz clock signal to the right pin on the 18 pin socket.
16F84A oscillator options do not have a 'clock' or timer word. 16F818 does have one that sounds more like it.
Will try a couple things.
