AussieSusan wrote:Before spinning off on another problem (clock speed), have you solved the problem with not entering the 'then' clause o the 'if' statement?
Yes I kept preiod as float .and its working.
but I wanted to achive a frequency of 1280,000Hz, by reaching pr5=12 .I was only able to reach pr5=21 with stepwave . Its not able to toggle Stepwave beyond that.
If I omit Stepwave from code It easily reach upto pr5=12 (i.e. 1280000Hz). These are limitations I think.
Thank you.
