Greetings
Greetings
Postby Dren » Fri Jul 15, 2016 9:20 am
Hello All,
I've just joined this forum site after become more annoyed with the lack of support from Microchip. RTFM does not count as support in my book ! Esp when the datasheet is at best ambiguous or, more likely, just plain wrong.
I have been using PICs since the end of the 80s (the 14 series) I am currently working as a contract design engineer. I have designed using ICs from probably all the major microcontroller manufacturers over the last ~30 years.
The project I have been brought into uses the PIC24EP256GU814, an annoying device that does not seem to be supported my either MLA, Harmony or the MCC !
Over the next week I will be looking at adding I2C and USB interfaces. I would be grateful if there is a good code library I.E, one with well written code + comments + layout.
All the best
Dren
Dren
Re: Greetings
Postby vloki » Fri Jul 15, 2016 9:43 am
The MLA contains USB examples for PIC24EP512GU810 which should be similar to your PIC.
May it is usefull. What kind of USB interface you want to implement?
Re: Greetings
Postby Eddy_D » Fri Jul 15, 2016 11:19 pm
Greets, I'm using the pic24EP512GP206 myself.. it's a strange bird.. I treat it the same as a dsPIC33 and it make things a bit better (I suspect it's internals are basically a dsPIC33 anyways).
- Eddy
Eddy_D
