Re: Simplified Microchip PIC USB demos (C18/XC8 MLA v2013_12
Postby vloki » Fri Oct 17, 2014 7:26 am
Do not modify any file of the framework !!!
Setting the path is not that complicated.
The string found in the preferences dialog together with the #include "...."
is the path to go from the projects folder.
<edit>
BTW: there is no need to switch to newer MLA at the moment
Postby Interrupt » Fri Oct 17, 2014 10:55 pm
I think I finally cracked the include path!!! well complier is not shouting at me any more!!
The path shown in .jpeg VlokiUSB2 is to the mla within the project folder.
(still don't really understand the "go up 6 levels" )
C:\microchip\mla\v2013_12_20\framework (I only count 5 levels to and including "framework")
E:\PicProjects\PicUSB\USB_Vloki\LPC_FSUSB-HID-X-r1\src\mla\v2013_12_20\framework (I only count 8 levels to and including "framework")
Can you please explain
But now I have a few compiler errors ...please see attached pics.
I've also attached the zip of the project file.
LPC_FSUSB-HID-X.X_nd.zip
(44.12 KiB) Downloaded 1439 times
this path is to the mla within the project folder
Interrupt
Postby Interrupt » Fri Oct 17, 2014 11:26 pm
I think the penny has dropped with the include path level thing.....please see attached .jpeg and please enlighten me if I'm wrong!
include Directories_cracked.jpg (33.61 KiB) Viewed 24723 times
Interrupt
Postby vloki » Sat Oct 18, 2014 8:14 am
No ;-)
The project directory is ...\src\LPC-FSUSB-HID.X.X
From there you have to go one up to come to src -> "..\"
From "src" you go down to mla -> "mla\v2013_12_20\framework"
"..\" + "mla\v2013_12_20\framework" -> "..\mla\v2013_12_20\framework"
Postby vloki » Tue Nov 04, 2014 8:49 am
giorgik wrote:Hi vloki, interesting your post. I use MLA current: mla_v2014_07_22_windows_installer.exe.
In your post you put only the figure of the HID terminal and you did not put the project or the executable...
Ok, finally I added a (buggy) project and updated the screenshots
Postby ashes1312 » Wed Dec 31, 2014 5:26 am
Brilliant work vloki! Was spending endless hours on forums till I got here!
Cheers!
ashes1312
Re: Simplified Microchip PIC USB demos (C18/XC8 MLA)
Postby vloki » Tue Jan 13, 2015 3:26 pm
12. Jan. 2015 -> added PIC18F25K50 configurations and switched to MLA v2014_07_22
Postby TC49 » Tue Apr 21, 2015 1:33 pm
Hello all,
Thank you vloki for your post! works good on my quick little test setup :D
To prevent having to mess around with the paths, simply install the mla library first in C:/microchip/mla/v2013...xxx (this just happens to be the default location while installing this ;)
Then unpack the zip file from vloki in: C:/microchip/mla/v2013_12_22/apps/usb/device.
Worked fine for me when I installed it like this. (yes, I had the path issues at first when using different unpack location.)
TC49
Postby vloki » Tue Apr 21, 2015 1:45 pm
TC49 wrote:Hello all,
Which combination did you install ?
I thought that i added all necessary files into the package now :-(
Postby TC49 » Wed Apr 22, 2015 10:19 am
Your xxxr2 at the top of this topic and mla 2013_12_20. Wouldn't worry to much about it, just have the folks install it in the right place.
TC49
