What is Epoxy lens/case
Postby LED » Wed Sep 26, 2018 6:57 am
Hello
What is epoxy lens/case
what does epoxy lens/case do in led why it is made for it
LED
Banned
Re: What is Epoxy lens/case
Postby KTrenholm » Wed Sep 26, 2018 9:42 pm
It's the casing of an LED.
First result for "Epoxy Lens" in google:
http://beaconlamps.com/blog/the-components-of-leds-and-how-they-work-3502
The epoxy lens has three major functions. First, it is designed to allow most of the light to escape from the semiconductor. Second, it focuses the light (view angle) and lastly, it protects the LED semiconductor from outside elements. The epoxy totally embeds the entire unit which makes the LED virtually indestructible. There are no loose or moving parts within the solid epoxy enclosure. Non-diffused lenses that do not have glass particles in the epoxy produce a narrow viewing angle of +/-12 degrees from the centre.
KTrenholm
Postby LED » Fri Sep 28, 2018 1:26 pm
Hello
Which material is this epoxy lens made of.
LED
Banned
Postby KTrenholm » Fri Sep 28, 2018 2:19 pm
Gee I wonder...
KTrenholm
Postby ric » Fri Sep 28, 2018 2:32 pm
LED wrote:Hello
I'm going to take a wild guess, and say "epoxy".
Are you really this slow, or are you just putting it on?
Postby jtemples » Fri Sep 28, 2018 7:20 pm
How can I make epoxy with a PIC!
Postby vloki » Sat Sep 29, 2018 7:43 pm
jtemples wrote:How can I make epoxy with a PIC!
LCD_ConstTextOut(0,0,"epoxy";-)
Postby LED » Wed Oct 03, 2018 11:13 am
Hello
Does making led in usa use code
LED
Banned
Postby ric » Wed Oct 03, 2018 11:31 am
LED wrote:Hello
What on earth are you asking?
