It was just 24hrs ago.
Postby elZero » Sat Aug 04, 2018 5:18 am
I was challenged yesterday, to learn about Microcontrollers. I have not had any training whatsoever on how to use them. Was introduced to this forum by the guy who challenged me. So, here I am. Would appreciate all the help I can get, to navigate this learning curve.
elZero
Re: It was just 24hrs ago.
Postby ric » Sat Aug 04, 2018 11:01 am
It would be a bit easier to sugest where to start if you explain what level you are already at.
Postby elZero » Sat Aug 04, 2018 2:06 pm
ric wrote:It would be a bit easier to sugest where to start if you explain what level you are already at.
I am right now going through the lessons from Gooligum Electronics, and also reading a text on C Programming for embedded systems. I've had some experience programming with C for general computers. So, I guess I am at the lowest level possible.
elZero
Postby Jorgef » Sun Aug 05, 2018 5:06 am
Hi
The Gooligum tutorials are good.
As far as I can see, you are starting with the correct foot.
If you don't grab some detail of a tutorial, ask, we will help.
Best regards
Jorge
Jorgef
Postby CharlesCarvalho » Sat Sep 08, 2018 12:28 pm
Jorgef wrote:Hi
As far as I can see, you are starting to with the correct foot. If you don't grab some phenq GNC deals detail of a tutorial, ask, we will and help.
This "helping spirit" makes this forum great. I can also use the new here and want to learn everything! Will ask for help if necessary.
Last edited by CharlesCarvalho on Mon Oct 23, 2023 8:02 pm, edited 3 times in total.
CharlesCarvalho
Postby BobbyGibson » Sun Oct 30, 2022 1:49 pm
Jorgefs wrote:Hi
As far as I found best weight loss pills over the counter here and more can see, you are starting with the correct foot.
Behind the wheel just went along. I'm tired of hearing the same old song. Look I rule the night. No end in sight.
BobbyGibson
