Page 1 of 2
Reviving old posts
Fri Jun 27, 2014 11:33 pm
by jtemples
Someone just followed up to a 23-year-old post with an off-topic reply in comp.lang.c:
https://groups.google.com/forum/#!msg/comp.lang.c/r1exOL5Y1vU/IMnLAjIeiAIJ
Re: Reviving old posts
Sat Jun 28, 2014 12:23 am
"ahhh, I'll just pop it here, it looks vaguely C related."
Sat Jul 05, 2014 4:33 am
by Ian.M
As a tribute to that, I've just booted up my approx 30 year old Sinclair QL, which over the years was upgraded with a 68020 and 4MB RAM, a 40MB HDD and various other goodies including a mouse driven true multitasking window manager released two years before Windows 3.0 and an ANSI C compiler. I wonder if it would be possible to use it for PIC development? [lol]
Sat Jul 05, 2014 5:32 am
Do you think you could get Linux running on it?
Sat Jul 05, 2014 6:29 am
by Ian.M
That's a touch tricky because there is no MMU or FPU, so standard LINUXes wont run, but uClinux can run without a MMU and I believe there is a 68020 port. I'd have to dig out the 68020 accelerator card's low level documentation to see how it copies system ROM to RAM, patches it and protects it because I suspect I'll need to overwrite that with the kernal image. There is a Linux port on the Q40 (a 68040 based QL successor) so some of the hardware drivers required could probably be back-ported from that.
There is also an IBM PC emulator which I believe I *MIGHT* still have copy of so I suppose I could run an ancient DOS copy of the Microchip Assembler (MPALC).
Sat Jul 05, 2014 8:07 pm
by jtemples
I've got original IBM DOS 1.0 floppies if you need them.
Thu Jul 10, 2014 11:59 pm
by mlp
Aside from your being a very ill man, John, I suspect those floppies are now transparent mylar discs with a pile of oxide in the bottom of the sleeve.
Fri Jul 11, 2014 2:14 am
by jtemples
Alright, I'll get them out and inspect them when I get home tonight. I don't think they've seen daylight in at least 15 years.
Fri Jul 11, 2014 2:33 am
I assume they are 5ΒΌ" floppies.
Do you have anything that can still read them?
Fri Jul 11, 2014 3:05 am
by jtemples
I'm afraid the PC that they came with is no longer with us...
