Reviving old posts
Reviving old posts
Postby jtemples » Fri Jun 27, 2014 11:33 pm
Someone just followed up to a 23-year-old post with an off-topic reply in comp.lang.c:
https://groups.google.com/forum/#!msg/comp.lang.c/r1exOL5Y1vU/IMnLAjIeiAIJ
Re: Reviving old posts
Postby ric » Sat Jun 28, 2014 12:23 am
:lol:
"ahhh, I'll just pop it here, it looks vaguely C related."
Postby Ian.M » Sat Jul 05, 2014 4:33 am
As a tribute to that, I've just booted up my approx 30 year old Sinclair QL, which over the years was upgraded with a 68020 and 4MB RAM, a 40MB HDD and various other goodies including a mouse driven true multitasking window manager released two years before Windows 3.0 and an ANSI C compiler. I wonder if it would be possible to use it for PIC development? [lol]
Postby ric » Sat Jul 05, 2014 5:32 am
Do you think you could get Linux running on it? :)
Postby Ian.M » Sat Jul 05, 2014 6:29 am
That's a touch tricky because there is no MMU or FPU, so standard LINUXes wont run, but uClinux can run without a MMU and I believe there is a 68020 port. I'd have to dig out the 68020 accelerator card's low level documentation to see how it copies system ROM to RAM, patches it and protects it because I suspect I'll need to overwrite that with the kernal image. There is a Linux port on the Q40 (a 68040 based QL successor) so some of the hardware drivers required could probably be back-ported from that.
There is also an IBM PC emulator which I believe I *MIGHT* still have copy of so I suppose I could run an ancient DOS copy of the Microchip Assembler (MPALC).
Postby jtemples » Sat Jul 05, 2014 8:07 pm
I've got original IBM DOS 1.0 floppies if you need them.
Postby mlp » Thu Jul 10, 2014 11:59 pm
Aside from your being a very ill man, John, I suspect those floppies are now transparent mylar discs with a pile of oxide in the bottom of the sleeve.
Please, before you post, read the Forum Guidelines
and How To Ask Questions The Smart Way.
Mark (not paid to state the opinions of Microchip Technology Inc.)
mlp
Postby jtemples » Fri Jul 11, 2014 2:14 am
Alright, I'll get them out and inspect them when I get home tonight. I don't think they've seen daylight in at least 15 years.
Postby ric » Fri Jul 11, 2014 2:33 am
I assume they are 5¼" floppies.
Do you have anything that can still read them? 8-)
Postby jtemples » Fri Jul 11, 2014 3:05 am
I'm afraid the PC that they came with is no longer with us...
