Lost Communication between PIC and PC - Help!
Hi everyone,
I'm having a major headache trying to get my PIC16F877A to consistently communicate with my PC over UART. I'm using a USB to Serial adapter (FTDI) and have checked the wiring countless times.
The problem is intermittent. Sometimes the PIC sends data that the PC receives perfectly, other times it's just garbage or nothing at all. I've tried different baud rates, checked for framing errors, and even swapped out the PIC itself, but the issue persists.
Here's a snippet of my code (using MPLAB XC8):
```c
void main(void) {
// Configuration bits... (omitted for brevity)
// UART initialization
TXSTA = 0x20; // Enable transmit, asynchronous mode
RCSTA = 0x90; // Enable receive, serial port
SPBRG = 25; // 9600 baud rate (assuming 4MHz oscillator)
while(1) {
// Send a test message
TXREG = 'H';
while(!TXIF);
TXIF = 0;
__delay_ms(100);
TXREG = 'e';
while(!TXIF);
TXIF = 0;
__delay_ms(100);
TXREG = 'l';
while(!TXIF);
TXIF = 0;
__delay_ms(100);
TXREG = 'l';
while(!TXIF);
TXIF = 0;
__delay_ms(100);
TXREG = 'o';
while(!TXIF);
TXIF = 0;
__delay_ms(100);
TXREG = '!';
while(!TXIF);
TXIF = 0;
__delay_ms(1000);
I suspect there might be an issue with the timing or maybe some interference. I've tried adding decoupling capacitors near the PIC, but it didn't seem to help.
Has anyone encountered a similar problem? Any suggestions on what to check next? I'm pulling my hair out! Any help would be greatly appreciated.
Thanks in advance!.
```c
void main(void) {
while(1) {
TXREG = 'H';
while(!TXIF);
TXIF = 0;
__delay_ms(100);
TXREG = 'e';
while(!TXIF);
TXIF = 0;
__delay_ms(100);
TXREG = 'l';
while(!TXIF);
TXIF = 0;
__delay_ms(100);
TXREG = 'l';
while(!TXIF);
TXIF = 0;
__delay_ms(100);
TXREG = 'o';
while(!TXIF);
TXIF = 0;
__delay_ms(100);
TXREG = '!';
while(!TXIF);
TXIF = 0;
__delay_ms(1000);
Thanks in advance!.
