What is name of this cut
Postby LED » Wed Oct 03, 2018 7:38 am
Hello
What is name of this cut in PIC16F877A what is it called
embeded system.jpg (36.17 KiB) Viewed 8564 times
LED
Banned
Re: What is name of this cut
Postby KTrenholm » Wed Oct 03, 2018 6:39 pm
"Cut"?
What are you asking?
the notch?
KTrenholm
Postby LED » Thu Oct 04, 2018 6:36 am
Hello
Is this semi circle called notch
LED
Banned
Postby ric » Thu Oct 04, 2018 11:06 pm
Yes
Postby AussieSusan » Fri Oct 05, 2018 3:20 am
The purpose of the notch is the same as having a dot on other packages - to tell you which way around the IC should be installed on the board.
Typically the notch or dot is near Pin #1.
Postby LED » Fri Oct 05, 2018 8:32 am
hELLO
hOW THIS NOTCH ORDOT IS MADE
LED
Banned
Postby ric » Fri Oct 05, 2018 9:03 am
Why on earth do you care?
These questions really are getting silly again!
Last warning. Ask sensible questions, or I will turn off your account.
