Draft FAQ for "Digital I/O Ports" forum
A place to start writing FAQ posts for other forums. Make your daft in here, then it can be moved to the correct forum when complete.
Postby ric » Sat May 31, 2014 2:45 am
Topics
  • Port pins changing unexpectedly - the "Read-Modify-Write" problem
  • Inputs always reading as zero - Analog capable inputs default to analog mode
The following examples in Assembler and C do exactly the same thing:
Example assembler
        clrf    PORTA   ;All pins low
        ....            ;some other instructions
        bsf     PORTA,0 ;raise RA0
        bsf     PORTA,1 ;raise RA1
Example C
    PORTA=0;    //All pins low
    ....            //some other instructions
    PORTAbits.RA0=1    //raise RA0
    PORTAbits.RA1=1    //raise RA1
(More to write)
Inputs always reading as zero - Analog capable inputs default to "analog" mode
(To write)
Re: Draft FAQ for "Digital I/O Ports" forum
Postby Ian.M » Sat May 31, 2014 11:20 am
Some stuff you may wish to add that needs expanding:
* Capacitive Loading Specs on Output Pins 50pF max - consistent across 8 bit PIC families ever since the PIC16C devices
ToDo: Confirm loading specs for 16 and 32 bit families.
* Influence of loading and clock speed on RMW problem.
* Methods of avoiding RMW:
+ Use LATX if available (Dario's favourite 8-)
+ Shadowing
+ Avoidance by only using one output per port
+ Avoidance by only writing whole port
+ Mitigation by delays
* Link back to "RMW and solutions for it" http://www.microchip.com/forums/m478014.aspx
Return to FAQ Factory
