Posted: Wed May 28, 2014 3:47 am
- Download previous versions of MPLAB X and MPLAB 8 (Link updated 12-Sep-2017) (Link updated again 5-Jan-2024)
- MAPS - Microchip Advanced Part selector
- DTS - Development Tools Selector
- Shop online at Microchip Direct
- The easy way to set CONFIG bits in your source using MPLABX (on Microchip Wiki)
- PIC24/dsPIC Legacy Peripheral Libraries
- MPLAB C18 to XC8 C Compiler Migration Guide - Microchip
- Appnote: Transmit infra-red commands using RC5 or SIRC.
- Hardware Tool Debug Features by Device
- AC zero cross detection. TB3013 supersedes AN521.
- Backup of DM160215 software (USB to DALI interface project)
- What's new in XC8 v2.0 (on Microchip Developer website)
- Moving from XC8 v1.xx to v2.0
- How to fix "Could not connect to tool hardware: PICkit3PlatformTool - The debugger could not be started. Terminating debug session"
- MPLAB-X-MCC-plugin--MCC-Core-and-MCC-Harmony-Core-versions-and-compatibility
- PICkit4 overshoot modification
- RMW (Read Modify Write) problem explained
- RMW and solutions for it (A compilation of Read-Modify-Write solutions collated by Stefan Uhlemayr)
- Flying with SoftWare Favorites Gallery List
- Random USB freezes when using Microsoft CDC driver
- Lost clock CAL value in PIC12F675 chips
- ICSP wiring recommendations.
- PIC programmers. Which ones work, and which to avoid. Created by Ian.M
- ASM30 no longer supplied with MPLABX, use XC16 instead.
- Crystal Oscillator FAQ
- What MPLABX requires to see a folder as a project
- How to reliably initialise character LCD displays.
- How to install XC8 version 1.34 and later into MPLAB8.
- Why your code should not write to EEPROM straight after power on
- Why unoptimised output from C compiler is so bloated.
- Optimal routines to convert 16 bit hex to BCD on 8 bit PICs. (i1ctg and 1and0 together created a masterpiece) (Link fixed 1-Feb-2024)
- XC8 Table Array Workaround for PIC18FXXK40, Silicon Rev A3 (Array init failing)
- Fix PICkit3 unreliable communication by disabling Enhanced Power Management in Windows Registry
- Initialise and read 14 bit data from FLASH on PIC16F devices using XC8.
- Ability of some Microchip tools to read FLASH/EEPROM memory in debug mode (also https://www.microchip.com/forums/FindPost/1043101 )
- Why XC8 does not support the PIC18 Extended Instruction set (XINST)
- Never enable "Local code generation" in XC8 and background from the horse's mouth here
- C code for 16x16 to 32 bit signed int multiply
- PIC-AS examples
- Gooligum Tutorials for base and mid-range PICs.
- PIC Development Tools from "Embed Inc" (Olin Lathrop)
- Frequently Asked Questions (FAQ) about C on the Microchip PIC (Hitech C, XC8 and C18 suggestions from jtemples)
- Using The Same I/O Pin For Input And Output from Joseph Watson
- Simple yet powerful serial terminal program for Windows PCs
- Debouncing Contacts and Switches in Embedded Systems
- why-adc-1024-is-correct-and-adc-1023-is-just-plain-wrong
- Organizing Code Files in C and C++ (Ignore the C++ specific bits)
- What Every Computer Scientist Should Know About Floating-Point Arithmetic
- Reason of Multiple GND and VCC on an IC.
- Generate precise software delays on any PIC16 or PIC18 chip (from PICLIST.COM)
- RS422 and RS485 Standards Overview (TI appnote)
