My Real-Ice doesn't work anymore
Hi to everybody,
I have a problem with my Real-Ice. I use it with MPLAB-X 2.30 (but I have installed the 2.35 version and the problem is the same) and now, without a particular reason, it doesn't work anymore.
The problem started using the explorer16 and I'm sure that the board is ok because I can work with it using ICD3 emulator.
This is what MPLAB-X shows :
Connecting to MPLAB REAL ICE...
Currently loaded firmware on REAL ICE
Firmware Suite Version.....01.35.16 *
Firmware type..............dsPIC33F/24F/24H
Target voltage detected
Target Device ID (0x0) does not match expected Device ID (0x101e0000).[/b][/b]
The device in question is a PIC24F256GA110 and it's OK because using ICD3 evrything is ok.
I tried with other boards and other microcontrollers but the problem persists.
Anyone can help me?
Thanks
Anyone can help me?
Thanks
