External oscillator for PIC32MK
I was planning to use a crystal, but have been persuaded to use an external oscillator module instead.
I'm looking at the ECS-3225SMV which is available in a range of frequencies between 8MHz and 60MHz.
The datasheet for the PIC32MK0512MCJ064-E/PT says the External Clock frequency can be up to 64MHz.
My question is what is the preferred frequency for an external clock to use with one of these (assuming no other considerations)?
If the answer it "it depends", then guidance on choosing the right frequency will be very helpful.
Thanks
David
Thanks
David
