[Solved] Create an Client/Server project with PIC32
Hello
I would like to create a simple TCP project (Client / Serevur) on a PIC32 ETHERNET STARTER KIT card that has a PIC32MX795F512L, Without using MPLAB Harmony.
To achieve this, I installed: MPLAB X IDE v4.20 and MPLAB IDE v8.90, for lack of experience, I do not know which one to use for this project !!.
I did a lot of research, but I only find projects and demos using Harmony (which I do not want to use), I also tested my card with a simple LED ignition program and it works very good.
Someone would have links on examples (Client/Server) and also the steps to follow for the realization of a project TCP/IP without going through Harmony (Installation of the stack TCP / IP ...)?
Thank you
Thank you
