Undefined reference to
Hi all, how are you?.
Since yesterday I have a problem, my code was working well and suddenly after doing some commits and merge's then when I try to compile the project to run the code it says this:
the problem is that I'm looking the master branch and all the files involved in it, I've merged all in the master branch and I can look all the files in the project tree (actual branch), even the library that calls the function that is giving me the error is included in main.
My main code is this:
and Confi_PuertoD is defined in E_S.h, of course the prtotype and the functions are well written and they doesn't have errors right now.
E_S.h is this:
and E_S.c is this:
I've followed the steps described in the following thread
https://www.microchip.com/forums/m938906.aspx
and I still have the same problem.
How can I solve this?
nbproject/Makefile-default.mk:163: recipe for target 'dist/default/production/Control_LCD.X.production.hex' failed
make[2]: Leaving directory 'C:/Users/valery/MPLABXProjects/Control_LCD.X'
nbproject/Makefile-default.mk:90: recipe for target '.build-conf' failed
make[1]: Leaving directory 'C:/Users/valery/MPLABXProjects/Control_LCD.X'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
build/default/production/main.o(.text+0x8): In function `_main':
: undefined reference to `_Confi_PuertoD'
make[2]: *** [dist/default/production/Control_LCD.X.production.hex] Error 255
BUILD FAILED (exit value 2, total time: 4s)
#include "sistema.h"
#include "E_S.h"
int main(void) {
Tipo_Osc(PROSC);
Confi_PuertoD(0b1111000000000000);
LATD = 0b1010101010101010;
while (1);
return 0;
E_S.h is this:
#ifndef E_S_H
#define E_S_H
#include <xc.h> // include processor files - each processor file is guarded.
void Confi_PuertoD(unsigned int pinesD); /* Prototipo de función para
* configurar el funcionamiento
* del puerto D. */
#endif /* E_S_H */
and E_S.c is this:
#include "E_S.h"
void Confi_PuertoD(unsigned int pinesD) /* Función para configurar el
* funcionamiento del puerto D. */
TRISD = pinesD;
ODCD = 0;
