Helpful Utility for posting large files
Hello all,
Attached is a simple utility I wrote to allow zip files to be cut into smaller sizes for posting on forums. I originally used this for sending files to somebody who had a 2Mb limit on their Email.
Hope somebody finds this useful.
When unzipped the EXE should be 105,472 bytes. If not don't use as somebody may have tampered with it.
Regards.
T Yorky
<EDIT>...
Problem with need for the Borland Run Time Libraries.
Attached is a 'slimmed down' version I have called TINYGLUE. This will only 'glue' together pre-cut up ZIP files. A cut up ZIP file has a set of files with the extension '.1AY'.
These '.1AY' files all need to be in a single folder. The utility retrieves the info from the first file and glues the ZIP back together based on this info.
The original folder must already exist. A simple warning message is created if not. The folder required is shown in this message so you can copy it to create it yourself.
Alternatively, the first file (_00.1AY) is an INI format so you can edit the ZIP destination folder directly.
The size of this unzipped utility is 496,640 bytes.
Within the next posts I will add the whole CUTITUP utility without the library issues. But this will need Gluing back together using TINYGLUE.
Regards.
T Yorky
<EDIT>...
