Bootloader / USB Oddity. USB Reset needed?
Postby cmj » Wed Mar 31, 2021 10:01 pm
Hello
A bit of a strange one?
I have a PIC24FJ64GB002 that I am using as a USB host - using with the Microchip USB host code. The PIC then uses SPI to communicate with another system (the PIC is the slave). That side of it is working.
I then added a simple bootloader. It will update the code okay, but when I jump to the main application from the bootloader, if the device (mouse in this case) is connected the USB side doesn't work for maybe a few minutes, then it kicks into life, as if something has timed out and reset something internally.
If I disconnect and reconnect the mouse, it works straight away. If I don't use the bootloader it works from power up. Both the application and loader are in C. I did try a very thing assembler "pre-loader" that would just check the state of a single digital input and either jump to the application or the loader, but even that didn't work (the test here was to set the input to 1, then tell the PIC to reset itself (with asm "reset") via the SPI link.
I suspect there is some sort of timing thing going on, but I can't see what. As far as I can tell the USB system isn't active during the bootloader (the red LED on the mouse doesn't light up until the application starts).
One solution would be to get the application to somehow reset the USB system as if the device had been reconnected, but I couldn't see how to do that.
Any suggestions would be most welcome.
Thanks
Chris
Re: Bootloader / USB Oddity. USB Reset needed?
Postby cmj » Thu Apr 01, 2021 9:12 am
Answering my own post, as there's nothing like posting a question to a forum to make you think of a solution..
Setting the POR bit in RCON seems to do it. I believe (from reading somewhere online) it causes the C runtime to reinitalise itself.
Postby AussieSusan » Tue Apr 06, 2021 8:27 am
That all depends on how you are passing control between the bootloader and the application.
Normally the C runtime is the first thing to get control on any reset (i.e. the use of the address that is stored at 0x0000 in the program space). The C runtime sets up the stack, initialises global variables etc, before passing control to your 'main()' function. Depending on the C compiler, if the 'main()' function ever exits, the runtime will repeat the startup sequence and re-call the 'main()' function.
If the bootloader is the code that receives control following a reset, and you say that the bootloader is written in C, then the environment that is initialised will probably not be that of your application.
Alternatively if your app received the reset and as part of its startup, it tests to see if the bootloader should be activated, then the story may be quite different.
Return to PIC24
