Print graph on a thermal printer
Postby Manoj » Mon Apr 22, 2019 12:49 pm
I am using PIC24fj256gb110 .
I am already using a thermal printer.to print text.
Want to know how to print and X-Y graph on it.
Expecting your help.
Thankyou. Manoj Hader
Manoj
Re: Print graph on a thermal printer
Postby AussieSusan » Tue Apr 23, 2019 3:41 am
Don't start with the MCU - start with the thermal printer and how you need to communicate with it.
Get the data sheet and see what you need to send to the printer to have it place a dot at a specific location.
Then you can work out if the printer has limitations such as if you need to send all of the 'X' points (assuming this is across the page) before you move to the next 'Y' location etc..
Once you know this then you can work out how to convert whatever information you have that describes the graph into the appropriate format to send to the printer.
Postby Manoj » Fri Apr 26, 2019 8:08 am
Is there any possibility ,if i can generate a .jpeg or.bmp file of the graph and then sent it to printer?
Manoj
Postby jtemples » Sat Apr 27, 2019 5:17 am
How could anyone here possibly know the answer to that when you haven't shared the model number of the printer?
Postby Manoj » Mon Apr 29, 2019 5:18 am
Oh,sorry about that.
I am also thinking of implementing HC 05 bluetooth module:-
https://www.amazon.in/ROBIOT-HC-05-Blue ... 267&sr=1-4
and interfacing with this type of filter mentioned below:-
https://www.amazon.in/Pegasus-Portable- ... dr18418-21
Manoj
Postby AussieSusan » Tue Apr 30, 2019 3:26 am
In the link you provide for the printer is the comment " Programming Guide included in CD or downloadable from Manufacture website."
That could be the starting point for you.
Return to PIC24
