Inputs on PIC16LF15313 not working
Postby Christopher.Ash » Mon Feb 11, 2019 5:25 pm
I am trying to get a PIC16LF15313 to read a high on either RA1 or RA2 however it does not seem to recognize that the pins are high. I am using the PIC as a slave on an I2C bus and the Master is sending a high to the PIC for it to set up itself for I2C communication. The I2C communication is working fine, however even though the pin has a voltage of 3.15V it is not recognizing that either RA1 or RA2 is high in the code. Please see my code below. In the code I have RA2 as the input, I did this after trying to set RA1 as the input and saw that it was not working, therefore I tired RA2 and got the same problem. Both pins work fine as outputs.
Please feel free to ask anymore questions and I apologize if my mistake is trivial. I am not very experienced with Micro-controllers (I am a engineering student working on a project). Thank you so much for your time, I really do appreciate any help that you can give. Also please feel free to critique my work in any way that you see fit.
 * File:   newmain.c
 * Author: Christopher
 * Created on January 30, 2019, 1:00 PM
// CONFIG1
#pragma config FEXTOSC = OFF    // External Oscillator mode selection bits (Oscillator not enabled)
#pragma config RSTOSC = HFINT32 // Power-up default value for COSC bits (HFINTOSC with OSCFRQ= 32 MHz and CDIV = 1:1)
#pragma config CLKOUTEN = OFF   // Clock Out Enable bit (CLKOUT function is disabled; i/o or oscillator function on OSC2)
#pragma config CSWEN = OFF      // Clock Switch Enable bit (The NOSC and NDIV bits cannot be changed by user software)
#pragma config FCMEN = OFF       // Fail-Safe Clock Monitor Enable bit (FSCM timer enabled)
// CONFIG2
#pragma config MCLRE = ON       // Master Clear Enable bit (MCLR pin is Master Clear function)
#pragma config LPBOREN = OFF    // Low-Power BOR enable bit (ULPBOR disabled)
#pragma config BOREN = OFF      // Brown-out reset enable bits (Brown-out reset disabled)
#pragma config BORV = LO        // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (VBOR) set to 1.9V on LF, and 2.45V on F Devices)
#pragma config ZCD = OFF        // Zero-cross detect disable (Zero-cross detect circuit is disabled at POR.)
#pragma config PPS1WAY = OFF    // Peripheral Pin Select one-way control (The PPSLOCK bit can be set and cleared repeatedly by software)
#pragma config STVREN = OFF     // Stack Overflow/Underflow Reset Enable bit (Stack Overflow or Underflow will not cause a reset)
// CONFIG3
#pragma config WDTCPS = WDTCPS_31// WDT Period Select bits (Divider ratio 1:65536; software control of WDTPS)
#pragma config WDTE = OFF       // WDT operating mode (WDT Disabled, SWDTEN is ignored)
#pragma config WDTCWS = WDTCWS_7// WDT Window Select bits (window always open (100%); software control; keyed access not required)
#pragma config WDTCCS = SC      // WDT input clock selector (Software Control)
// CONFIG4
#pragma config BBSIZE = BB512   // Boot Block Size Selection bits (512 words boot block size)
#pragma config BBEN = OFF       // Boot Block Enable bit (Boot Block disabled)
#pragma config SAFEN = OFF      // SAF Enable bit (SAF disabled)
#pragma config WRTAPP = OFF     // Application Block Write Protection bit (Application Block not write protected)
#pragma config WRTB = OFF       // Boot Block Write Protection bit (Boot Block not write protected)
#pragma config WRTC = OFF       // Configuration Register Write Protection bit (Configuration Register not write protected)
#pragma config WRTSAF = OFF     // Storage Area Flash Write Protection bit (SAF not write protected)
#pragma config LVP = OFF        // Low Voltage Programming Enable bit (High Voltage on MCLR/Vpp must be used for programming)
// CONFIG5
#pragma config CP = OFF         // UserNVM Program memory code protection bit (UserNVM code protection disabled)
#define _XTAL_FREQ 4000000
#include <pic16lf15313.h>
short z;
void __interrupt() ISR(void)
    if(SSP1IF == 1){
        SSP1CON1bits.CKP = 0;     //holds clock low
        if ((!SSP1STATbits.D_nA)&&(!SSP1STATbits.R_nW)){        //If last byte was Address plus write
            z = SSP1BUF;                                        //read SSPBUF to clear BF
        else if(SSP1STATbits.D_nA){                             //If last byte received was data
            z = SSP1BUF;                                        //read SSPBUF to clear it
            SSPOV = 0;                                          //clears overflow bit
            if(z == 0xFF){
                PORTAbits.RA0 = 1;
            else{
                if(z == 0x00){
                    PORTAbits.RA0 = 0;
                else{                                                   //If data sent is not 0x00 or 0xFF then data being sent is the new device ID
                    SSP1ADD = z;
                    PORTAbits.RA1 = 0;                                  //turn on enable for next device in chain
    SSP1CON1bits.CKP = 1; //releases clock
    SSP1IF = 0;          //sets the interrupt flag back to zero
    return;
void I2C_Slave_Init(short address){
    TRISAbits.TRISA4 = 1;           //sets clock pin (SCL) RA4 as an input
    TRISAbits.TRISA5 = 1;           //sets data pin (SDA) RA5 as an input
    SSP1STAT = 0X00;
    SSP1BUF = 0x00;  //clears buffer register
    SSP1ADD = address;
    SSP1CON1 = 0b00110110;        //Enables serial port (bit 6) and Releases clock (bit 5) and I2C save mode (bits 3 - 0)
    SSP1CON2 = 0b00000000;
    SSP1CON3 = 0b00000000;
    GIE = 1;        //enables global interrupts
    PEIE = 1;       //enable peripheral interrupts
    SSP1IF = 0;      // sets the interrupt flag for I2C is low
    SSP1IE = 1;      //enables I2C interrupts
    return;
void I2C_Pin_Init(){
    PPSLOCK = 0x55;
    PPSLOCK = 0xAA;
    PPSLOCK = 0x00;                 //unlock the peripheral select module
    RA4PPS = 0x15;                  //Changes the RA4 output to SCL
    RA5PPS = 0x16;                  //Changes the RA5 output to SDA
    SSP1CLKPPS = 0x04;             //Changes the SCL input pin to RA4
    SSP1DATPPS = 0x05;             //Changes the SDA input pin to RA5
    PPSLOCK = 0x55;
    PPSLOCK = 0xAA;
    PPSLOCK = 0x01;                 //locks the peripheral select module
    ANSELA = 0;
    OSCFRQ = 0x04;                      //sets internal oscillator to 4MHz
    TRISAbits.TRISA0 = 0;               //LED pin as an output
    PORTAbits.RA0 = 0;                  //ensures LED is off
    TRISAbits.TRISA1 = 0;               //output for initialization
    TRISAbits.TRISA2 = 1;               //input for initialization
    PORTAbits.RA1 = 0;                  //ensures that output for initialization is low
    while(PORTAbits.RA2 == 0){              //wait for initialization signal
    PORTAbits.RA1 = 1;
    I2C_Pin_Init();
    I2C_Slave_Init(0xFC);
    while(1);
    return;
Christopher.Ash
Re: Inputs on PIC16LF15313 not working
Postby Roche » Mon Feb 11, 2019 5:56 pm
You might want to check that pin you want to use is configured as a digital input when you want to read it...
Postby Christopher.Ash » Mon Feb 11, 2019 7:23 pm
Hello Roche,
Thank you for your response. I think they are configured as DIgital Inputs when I set ANSELA = 0. I could be wrong though, I'm not sure. Please correct me if I am mistaken. It's my first time using an 8 pin PIC. Thank you again for your time.
Christopher.Ash
Postby Christopher.Ash » Mon Feb 11, 2019 8:24 pm
Someone helped me find out what the problem was on another forum. It was where I had the ANSELA = 0 in the code. I had it occurring after the while loop checking the input pin hence the pin stayed configured as an analog pin, which is why is was not recognising the input. Thank you all for your time.
Christopher.Ash
Postby ric » Mon Feb 11, 2019 8:26 pm
Christopher.Ash wrote:Hello Roche,
The problem is, you don't write zero to ANSELA until you call I2C_Pin_Init(), and you don't call that until AFTER you have waited for the input to go high.
Move that instruction to your main() function right where you set the pin directions.
n.b. not your problem, but change
to
#define _XTAL_FREQ 32000000
and
to
xc.h has already included the device specific header for you, so don't do it again.
None of your code uses anything from stdio.h or stdlib.h. They are not used as often in an embedded system as in a Windows program, so get out of the habit of always including them.
Postby ric » Mon Feb 11, 2019 8:27 pm
I see you found the problem while I was typing up my answer. :)
Postby Christopher.Ash » Mon Feb 11, 2019 8:38 pm
Hello ric,
Yes but still thank you so much for your response. I really appreciate it. Thank you for your time.
Christopher.Ash
Postby Christopher.Ash » Mon Feb 11, 2019 9:06 pm
Hello again,
Now I'm trying to get the analog inputs to work so that I can use it for a light sensor. I'm almost certain that the ADC configuratin in the code works as I implemented the same code on a PIC16LF877A and it works there. However now that I ported the code over for a PIC16LF15313 it doesn't work. Whenever I read the sensor I am getting a constant value of 96. I do not think the problem is the same as before as it goes through the ANSELA bits before turning on the ADC. An help or even criticism is appreciated. Thank you for your time. Please see the code below:
 * File:   newmain.c
// CONFIG1
// CONFIG2
// CONFIG3
// CONFIG4
// CONFIG5
short z;
short l;
    if(SSP1IF == 1){
        else if(SSP1STATbits.R_nW){
             BF = 0;
             SSP1BUF = l;
             while(SSP1STATbits.BF);    //waits for data to send
    return;
    SSP1STAT = 0X00;
    SSP1ADD = address;
    return;
    PPSLOCK = 0x55;
    PPSLOCK = 0xAA;
    PPSLOCK = 0x55;
    PPSLOCK = 0xAA;
    ANSELAbits.ANSA0 = 1;
    ANSELAbits.ANSA1 = 0;
    ANSELAbits.ANSA2 = 0;
    ANSELAbits.ANSA4 = 0;
    ANSELAbits.ANSA5 = 0;
    int ADCval;
    int LI;
    ADCval = 0;         //initializing ADCval an LI before use
    LI = 0;
    I2C_Pin_Init();
    I2C_Slave_Init(0x04);
    ADCON0 = 0x40;
    ADCON1 = 0x80;
    TRISAbits.TRISA0 = 1;
    TRISAbits.TRISA2 = 0;
    PORTAbits.RA2 = 1;              //debugging LED
    while(1){
       ADON = 1;       //Turn on ADC
       GOnDONE = 1;   //Start Conversion
       while(GOnDONE);    //Wait for conversion to finish
       ADON = 0;           //turn off ADC
       ADCval = ((ADRESH<<8)|(ADRESL));    //store value read from ADC in variable
       LI = 100 - ((ADCval)/10.24);        //convert value read into Light Intensity %
       l = LI;
       __delay_ms(1000);       //wait for 1 sec
    return;
Christopher.Ash
Postby Christopher.Ash » Mon Feb 11, 2019 10:33 pm
I got an answer apparently I configured ADCON0 wrong in the code. It is supposed to 0x00 so that it would read RA0. However I'm not sure if this completely fixed the problem. Now I'm getting strange results from the light sensor. When I am testing it I am getting a value of 96 when the lights are on in the room and 93 when the lights are off. From previous tests done using the same circuit on a PIC16LF877A I got 86 when the lights are on in the room and 27 when the lights are off. I am thinking that maybe it is a hardware problem. I a simple potential divider circuit with an LDR as the Light Sensor circuit. The set resistor is a 10k ohm resistor. Thank you for your time.
Christopher.Ash
Postby ric » Mon Feb 11, 2019 10:40 pm
As you're getting answers here and at https://www.microchip.com/forums/m1085937.aspx it's probably better to stay just there, as it will be the same people answering on both forums.
