Sleep mode / IDLE with PIC16F18345
Hello everyone,
I want to implement the operation in low consumption with my PIC16F18345. l can operate in 3 mode:, IDLE, DOZE, SLEEP
-the mode type is set with the IDLEN bit of the CPUDOZE register
But here is my problem, is:
HOW TO ENTER IN LOW CONSUMPTION MODE ??
I would like :
1. Press the button, the led lights up and it returns to sleep mode.
2. 2nd press, we return to normal mode and the led flashes.
I would like :
// CONFIG1
#pragma config FEXTOSC = OFF // FEXTOSC External Oscillator mode Selection bits (Oscillator not enabled)
#pragma config RSTOSC = HFINT1 // Power-up default value for COSC bits (HFINTOSC (1MHz))
#pragma config CLKOUTEN = OFF // Clock Out Enable bit (CLKOUT function is disabled; I/O or oscillator function on OSC2)
#pragma config CSWEN = ON // Clock Switch Enable bit (Writing to NOSC and NDIV is allowed)
#pragma config FCMEN = ON // Fail-Safe Clock Monitor Enable (Fail-Safe Clock Monitor is enabled)
// CONFIG2
#pragma config MCLRE = ON // Master Clear Enable bit (MCLR/VPP pin function is MCLR; Weak pull-up enabled)
#pragma config PWRTE = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config WDTE = ON // Watchdog Timer Enable bits (WDT enabled, SWDTEN is ignored)
#pragma config LPBOREN = OFF // Low-power BOR enable bit (ULPBOR disabled)
#pragma config BOREN = SBOREN // Brown-out Reset Enable bits (Brown-out Reset enabled according to SBOREN)
#pragma config BORV = LOW // Brown-out Reset Voltage selection bit (Brown-out voltage (Vbor) set to 2.45V)
#pragma config PPS1WAY = OFF // PPSLOCK bit One-Way Set Enable bit (The PPSLOCK bit can be set and cleared repeatedly (subject to the unlock sequence))
#pragma config STVREN = OFF // Stack Overflow/Underflow Reset Enable bit (Stack Overflow or Underflow will not cause a Reset)
#pragma config DEBUG = OFF // Debugger enable bit (Background debugger disabled)
// CONFIG3
#pragma config WRT = OFF // User NVM self-write protection bits (Write protection off)
#pragma config LVP = ON // Low Voltage Programming Enable bit (Low Voltage programming enabled. MCLR/VPP pin function is MCLR. MCLRE configuration bit is ignored.)
// CONFIG4
#pragma config CP = OFF // User NVM Program Memory Code Protection bit (User NVM code protection disabled)
#pragma config CPD = OFF // Data NVM Memory Code Protection bit (Data NVM code protection disabled)
// PORT A
#define ICSPDAT RA0 // Port de programmation
#define POWER RA1 // Retour d etat charge batterie
#define MCLR RA3 // Port de programmation
#define Vactiv RA5 // Grille transistor ventilateur
// PORT B
#define ledR RB7 // +LED rouge
// PORT C
#define BP RC5 // Bouton poussoir
#define ON 0 // Led tirée au +VCC
#define OFF 1 // Led tiréé au gnd
#define _XTAL_FREQ 8000000 // Oscillateur réglé à 8MHz
int control; //
void interrupt Interrupt_bp (void)
if(PIR0bits.INTF)
PIR0bits.INTF = 0; // RAZ flag IT
control = ~control;
ledR = ~ledR;
if (BP == 1){
SLEEP();
void main(void) {
OSCCON1 = 0b01100000; // Oscillateur interne
OSCFRQ = 0b00000110; // Frequence oscillateur a 16MHz
CPUDOZE = 0b00000000; // Choix DOZE/IDLE mode pour economie d energie en veille
VREGCON = 0b00000010; // Choix DOZE/IDLE mode pour economie d energie en veille
// Reglages des entrees/sorties
TRISA = 0x0B; // Choix entrees/sorties
LATA = 0x00; // RAZ des ports
ANSELA = 0x00; // Choix mode analogique/numerique
WPUA = 0x02; // Resistances de pull-up interne
TRISB = 0x00; // Choix entrees/sorties
LATB = 0x80; // RAZ des ports
ANSELB = 0x00; // Choix mode analogique/numerique
WPUB = 0x00; // Resistances de pull-up interne
TRISC = 0x20; // Choix entrees/sorties
LATC = 0xC0; // RAZ des ports
ANSELC = 0x18; // Choix mode analogique/numerique
WPUC = 0x20; // Resistances de pull-up interne
//Reglage des interuptions
INTCON = 0b11000000; // Autorisation des interruptions
//Reglage des peripheriques
PIE0bits.TMR0IE = 0; // Valide l'interruption generee par le debordement du Timer0
PIE0bits.IOCIE = 1; // Valide le changement d'etat
PIE0bits.INTE = 1; // Autoise l'interruption sur un peripherique exterieur
PIR0bits.TMR0IF = 0; // RAZ flag IT
PIR0bits.IOCIF = 1; // Activation du front descendant
PIR0bits.INTF = 1; // Detection d'une interruption
ledR = 0;
control = 0;
while(1){
ledR = 1;
__delay_ms(1000);
ledR = 0;
__delay_ms(1000);
