displaying #v as hex value in MPASM
PIC forum current not letting me post so will try here. I am writing a dim macro to overcome issues such as 151 errors and to keep track of array sizes (I will probably add some 'typing' at a later stage such as int, uint int16 etc). Below is an example of filling up some memory and the macro. I am using #v to display the allocated memory locations for the enhanced 14-bit core PICs. I'm pretty sure I have it debugged, but it would be much much easier if the memory locations were displayed in hex. I can probably write a dec to hex macro, but it may already have been done. Has anyone written such a macro - most search tools make it very difficult to search for #v so I apologise in advance if this is a simple task.
Sean
Sean
PIC forum current not letting me post so will try here. I am writing a dim macro to overcome issues such as 151 errors. Below is an example of filling up some memory and the macro. I am using #v to display the allocated memory locations. I'm pretty sure I have it debugged and can probably write a dec to hex macro
#include<m16f1847.inc>
dim ara0, .10 ;10 bytes in shared memory from memory location: decimal 112 to 121
dim ara1, .04 ; 4 bytes in shared memory from memory location: decimal 122 to 125
dim ara2, .74 ;74 bytes in bank0 from memory location: decimal 32 to 105
dim ara3, .67 ;67 bytes in bank1 from memory location: decimal 160 to 226
dim ara4, .80 ;80 bytes in bank2 from memory location: decimal 288 to 367
dim ara5, .08 ; 8 bytes in bank3 from memory location: decimal 416 to 423
dim ara6, .01 ; 1 bytes in bank3 from memory location: decimal 424 to 424
dim ara7, .02 ; 2 bytes in bank3 from memory location: decimal 425 to 426
dim ara8, .79 ;79 bytes in bank4 from memory location: decimal 544 to 622
dim ara9, .40 ;40 bytes in bank5 from memory location: decimal 672 to 711
dim arab10, .40 ;40 bytes in bank5 from memory location: decimal 712 to 751
dim arab11, .01 ; 1 bytes in bank6 from memory location: decimal 800 to 800
dim arab12, .80 ;80 bytes in bank7 from memory location: decimal 928 to 1007
dim arab13, .80 ;80 bytes in bank8 from memory location: decimal 1056 to 1135
dim arab14, .80 ;80 bytes in bank9 from memory location: decimal 1184 to 1263
dim arab15, .80 ;80 bytes in bank10 from memory location: decimal 1312 to 1391
dim arab16, .80 ;80 bytes in bank11 from memory location: decimal 1440 to 1519
dim arab17, .48 ;80 bytes in bank12 from memory location: decimal 1568 to 1615
code 0
nop
end
;Macro here:
; dim
; reserves memory starting with shared memory and then bank0, bank1...bank12
; Overcomes 151 error problems by declaring shadow variables
; dim array,10 for example will produce assembler constants array0a,array1a,..,array9a
; It also produces an assembler constant array0v
variable point =0
variable bankc =-1
dim macro x,n
radix dec
errorlevel -207
if n> 0x50
error max array size decimal 80 you will need to use indirect addressing in flat mode
endif
variable i=0
if point == 0
variable point = 0x70
udata_shr
endif
if ((point+n-1) <0x80) & (bankc==-1)
x res #v(n)
while i<n
x#v(i)a equ point+i
i++
endw
point= point+i
messg x located in shared memory from memory location: decimal #v(point-n) to #v(point-1)
else
tempv=(point+n)-0x80*(point/0x80)
; messg point value #v(point) : n value #v(n) : tempv value #v(tempv)
if tempv >0x70
bankc = bankc+1
sect#v(bankc) udata 0x20+0x80*bankc
point = 0x20+0x80*bankc
i=0
endif
x res #v(n)
while i<n
x#v(i)a equ point+i
i++
endw
point= point+i
messg x located in bank#v(bankc) from memory location: decimal #v(point-n) to #v(point-1)
endif
x#v(0)s equ n ;Assembler Constant with size of array
errorlevel +207
endm
