RPOR15bits.RP30R = 1; meaning
Postby Manoj » Fri Aug 24, 2018 11:52 am
I am using pic24fj256gb110.
as I was aiming to use pwm for the first time using this mcu.
I got confused here.
RPOR15bits.RP30R = 1;// used to select the out put pin .But I can not figure out what '1' defines here.
I went htrough the datasheetand noticed 'RPOR15' & 'RP30R' are there.still dont under stand what is 1 for.
please kindly help me.
Reason: Moved topic from "Suggestions" to "16-Bit Core"
Manoj
Re: RPOR15bits.RP30R = 1; meaning
Postby ric » Fri Aug 24, 2018 1:16 pm
PIC24FJ256GB110 datasheet, page 138, table "TABLE 10-3: SELECTABLE OUTPUT SOURCES (MAPS FUNCTION TO OUTPUT)"
As I read that table, "1" will assign C1OUT to that pin.
