PIC18FxxK22 code examples
Re: PIC18FxxK22 code examples
Postby vloki » Sun Jul 06, 2014 11:09 am
vloki wrote:- Receiving serial data USART
void RS232_RX(void)
//--------------------------------------------------------------------- __init()
    OSCCONbits.IRCF = IRCF_4MHZ;
    LED_1_TRI = LED_2_TRI = LED_3_TRI = LED_4_TRI = OUTPUT_PIN;
    TX_TRI = RX_TRI = INPUT_PIN;
    SPBRG1 = 16;                    // 57600 for 4MHz
    SPBRGH1 = 0;
    TXSTA1bits.BRGH = 1;
    BAUDCON1bits.BRG16 = 1;
    RCSTA1bits.SPEN = 1;
    RCSTA1bits.CREN1 = 1;
//----------------------------------------------------------------------- main()
    while(1){
        unsigned char command;
        if(PIR1bits.RC1IF){
            command = RCREG1;
            switch(command){
                case '0': mSET_LED_1_OFF(); mSET_LED_2_OFF();
                          mSET_LED_3_OFF(); mSET_LED_4_OFF(); break;
                case '1': mSET_LED_1_ON(); break;
                case '2': mSET_LED_2_ON(); break;
                case '3': mSET_LED_3_ON(); break;
                case '4': mSET_LED_4_ON(); break;
                default: break;
Postby vloki » Sun Jul 06, 2014 11:10 am
vloki wrote:- Bidirectional USART communication
void MiniRS232(void)
    LED_1_TRI = OUTPUT_PIN;
    LED_2_TRI = OUTPUT_PIN;
    LED_3_TRI = OUTPUT_PIN;
    ENC_BTN_TRI = INPUT_PIN;
#define FOSC        4000000 // in a global header
#define BAUDRATE    19200   // ""
//#define SPBRG_VAL (((FOSC/BAUDRATE)+32)/64)-1   // BRG16=0, BGH=0 !
//#define SPBRG_VAL (((FOSC/BAUDRATE)+8)/16)-1    // BRG16=0, BGH=1 !
#define SPBRG_VAL (((FOSC/BAUDRATE)+2)/4)-1     // BRG16=1, BGH=1 !
    baud1USART(BAUD_IDLE_RX_PIN_STATE_HIGH &
                 BAUD_IDLE_TX_PIN_STATE_HIGH &
                 BAUD_16_BIT_RATE &
                 BAUD_WAKEUP_OFF &
                 BAUD_AUTO_OFF);
    Open1USART( USART_TX_INT_OFF & USART_RX_INT_OFF &
                USART_ASYNCH_MODE & USART_EIGHT_BIT &
                USART_CONT_RX &
                USART_BRGH_HIGH & USART_ADDEN_OFF,
                SPBRG_VAL );
    while(1){
        if(DataRdy1USART()){
            command = RCREG1;
            switch(command){
                case '1': mSET_LED_1_OFF(); break;
                case '2': mSET_LED_2_OFF(); break;
                case '3': mSET_LED_3_OFF(); break;
                case '4': mSET_LED_4_OFF(); break;
                case '5': mSET_LED_1_ON(); break;
                case '6': mSET_LED_2_ON(); break;
                case '7': mSET_LED_3_ON(); break;
                case '8': mSET_LED_4_ON(); break;
                case '9': mSET_LED_1_ON(); mSET_LED_2_ON();
                          mSET_LED_3_ON(); mSET_LED_4_ON(); break;
                case '?':
                    BTN_L_TRI = BTN_R_TRI = INPUT_PIN;
                    WAIT_BTN_CAP();
                    command = mGET_BTN_L();
                    command += 2 * mGET_ENC_BTN();
                    command += 4 * mGET_BTN_R();
                    if(command < 10)command += '0';
                    else command += 'A' - 10;
                    TXREG1 = command;
                    break;
                default: break;
            }//switch(command){
        }//if(DataRdy1USART()){
    }//while(1){
Postby Miljkoyu » Sun Oct 05, 2014 12:13 pm
Hi, this is the best post about PIC18FxxK22 for beginners. Thank you for that.
Do you translate your "Tutorial in German language" in English? It would be very useful.
Miljkoyu
Postby vloki » Thu Oct 16, 2014 10:53 am
Miljkoyu wrote:Hi, this is the best post about PIC18FxxK22 for beginners. Thank you for that.
Sorry, no progress here.
No one seemed to be interested ;-)
Postby vloki » Thu Nov 13, 2014 11:30 am
A complete MPLABX project with configurations for C18 / XC8 compiler
uCQ_HS-ULM_Base_20141113.zip
(21.8 KiB) Downloaded 2543 times
Postby vloki » Fri Nov 21, 2014 8:58 am
Placeholder for USART error handling
Placeholder for USART receiver interrupt mode
Postby vloki » Fri Nov 21, 2014 9:00 am
Placeholder for receiver with protocol and additional buffer
Postby vloki » Fri Nov 21, 2014 9:02 am
Placeholder for transmit with protocol and buffer
Postby jpnbino » Tue Jan 27, 2015 8:18 pm
Thank you a lot for the code. Very useful for me.
jpnbino
Return to Suggestions
