PIC32MZ0512EFE144 Not working with ipecmd
Hello so I have a hex file and I want to run it through ipecmd.exe or ipecmd.jar and program the device. I run the command through command line and in programs the device when I have the following command
java -jar ipecmd.jar -P32MZ0512EFE144 -TPICD3 -M -F"HexFile.hex" -OB or ./ipecmd.exe -TPICD3 -P32MZ0512EFE144 -F"eio500.hex" -M -OB
But I don't want to make a Banch Mode when I remove the -OB command it says the device is program but is not program correctly for some reason. I know is not programming correctly because I have a separate GUI program where I input its MAC Address and gives me back the information of the device like IP address etc. I use the same hex file and run it through IPE manually and it works. Any advice of what I am doing wrong?
