How to ask questions
Postby ric » Sun May 25, 2014 7:41 am
  • Always mention WHAT PIC you are working with
  • If at all relevant, mention which IDE (MPLAB 8, MPLAB X etc), which Compiler (and version) that you are working with.
  • If something is not working, state clearly "what you did", "what you expected to happen", and "what did happen".
    Just saying "it didn't work", or "it didn't work how I expected" doesn't help.
  • Show the code you are using. Use [CODE] tags around the code. Show the CONFIG setting you are using.
Return to Announcements
