How to use mcc generated code for UART ISR
Hello all,
I am working on Some embedded project[PIC MCU] where I will receive the data over UART..The received data will be usede to manipulate the operation of some RGB LEDs
For the moment I use polling method but I want to use Uart_ISR function to operate this
SO my question is How to use the MCC generated and overall the ISR function?
many thanks
Here is my code:
main.c
and my EUSART.c
many thanks
Here is my code:
main.c
#include "mcc_generated_files/mcc.h"
#include <stdlib.h>
#include <stdio.h>
#include "atoh.h"
#include "LED.h"
#define _XTAL_FREQ 16000000
#define FRAMESIZE 18
void main(void)
uint8_t data ,i,j;
uint16_t R_value, G_value ,B_value;
uint8_t value;
uint8_t RX_Buffer[FRAMESIZE] = {0};
uint8_t RGB_data[6] ,HEX_data[6];
// initialize the device
SYSTEM_Initialize();
INTERRUPT_GlobalInterruptEnable(); // Enable the Global Interrupts
INTERRUPT_PeripheralInterruptEnable(); // Enable the Peripheral Interrupts
while(1)
// EUSART_Write(0x61);
// if(RCIF == 1)
while (!RCIF)
data = EUSART_Read(); // Read received character
for (i = 0; i<FRAMESIZE ; i++)
RX_Buffer[i] = data;
EUSART_Write(data);
//check if any data is received
for (j = 0 ; j = 5; j++ ) // get the RGB value in the separate array
RGB_data[j] = RX_Buffer[j+3];
HEX_data[value] = RGB_data[j]/16;
if(RX_Buffer[0]=='R' && RX_Buffer[FRAMESIZE-1] == '\n')
//ASCII to HEX separate values by string functions
uint32_t number = (uint32_t)strtol(HEX_data, NULL, 16);
R_value = number >>16;
G_value = (number & 0xffff) >> 8;
B_value = (number & 0x0000FF);
//ASCII to HEX separate values by AtoH function
// R_value = (uint16_t) atoh(HEX_data[0], HEX_data[1]);
// G_value = (uint16_t) atoh(HEX_data[2], HEX_data[3]);
// B_value = (uint16_t) atoh(HEX_data[4], HEX_data[5]);
SetLedColor(R_value,G_value,B_value);
and my EUSART.c
#include "eusart.h"
Section: Macro Declarations
#define EUSART_TX_BUFFER_SIZE 8
#define EUSART_RX_BUFFER_SIZE 8
Section: Global Variables
static uint8_t eusartTxHead = 0;
static uint8_t eusartTxTail = 0;
static uint8_t eusartTxBuffer[EUSART_TX_BUFFER_SIZE];
volatile uint8_t eusartTxBufferRemaining;
static uint8_t eusartRxHead = 0;
static uint8_t eusartRxTail = 0;
static uint8_t eusartRxBuffer[EUSART_RX_BUFFER_SIZE];
volatile uint8_t eusartRxCount;
Section: EUSART APIs
void EUSART_Initialize(void)
// disable interrupts before changing states
PIE1bits.RCIE = 0;
PIE1bits.TXIE = 0;
// Set the EUSART module to the options selected in the user interface.
// ABDOVF no_overflow; SCKP Non-Inverted; BRG16 16bit_generator; WUE disabled; ABDEN disabled;
BAUDCON = 0x08;
// SPEN enabled; RX9 8-bit; CREN enabled; ADDEN disabled; SREN disabled;
RCSTA = 0x90;
// TX9 8-bit; TX9D 0; SENDB sync_break_complete; TXEN enabled; SYNC asynchronous; BRGH hi_speed; CSRC slave;
TXSTA = 0x24;
// Baud Rate = 9600; SPBRGL 160;
SPBRGL = 0xA0;
// Baud Rate = 9600; SPBRGH 1;
SPBRGH = 0x01;
// initializing the driver state
eusartTxHead = 0;
eusartTxTail = 0;
eusartTxBufferRemaining = sizeof(eusartTxBuffer);
eusartRxHead = 0;
eusartRxTail = 0;
eusartRxCount = 0;
// enable receive interrupt
PIE1bits.RCIE = 1;
uint8_t EUSART_Read(void)
uint8_t readValue = 0;
while(0 == eusartRxCount)
readValue = eusartRxBuffer[eusartRxTail++];
if(sizeof(eusartRxBuffer) <= eusartRxTail)
eusartRxTail = 0;
PIE1bits.RCIE = 0;
eusartRxCount--;
PIE1bits.RCIE = 1;
return readValue;
void EUSART_Write(uint8_t txData)
while(0 == eusartTxBufferRemaining)
if(0 == PIE1bits.TXIE)
TXREG = txData;
else
PIE1bits.TXIE = 0;
eusartTxBuffer[eusartTxHead++] = txData;
if(sizeof(eusartTxBuffer) <= eusartTxHead)
eusartTxHead = 0;
eusartTxBufferRemaining--;
PIE1bits.TXIE = 1;
void EUSART_Transmit_ISR(void)
// add your EUSART interrupt custom code
if(sizeof(eusartTxBuffer) > eusartTxBufferRemaining)
TXREG = eusartTxBuffer[eusartTxTail++];
if(sizeof(eusartTxBuffer) <= eusartTxTail)
eusartTxTail = 0;
eusartTxBufferRemaining++;
else
PIE1bits.TXIE = 0;
void EUSART_Receive_ISR(void)
if(1 == RCSTAbits.OERR)
// EUSART error - restart
RCSTAbits.CREN = 0;
RCSTAbits.CREN = 1;
// buffer overruns are ignored
eusartRxBuffer[eusartRxHead++] = RCREG;
if(sizeof(eusartRxBuffer) <= eusartRxHead)
eusartRxHead = 0;
eusartRxCount++;
void EUSART_Put(const unsigned char *string)
int i;
for (i=0;string[i]!='\0';i++)
EUSART_Write(string[i]);
