Problem verifying that my new PICKit4 is working properly
Postby t1d » Sun Jan 23, 2022 10:09 pm
Hi, Ric. The Microchip Forum firewall won't let me post. I got frustrated and came here for help. If, I do not have this thread in the correct topic, please feel free to move it.
RE:
PIC12F1840 – Brand New
MPLab X = v5.50
XC8 = v2.32
OS = Windows 10
Programmer = Brand New PICKit4
Novice C coding skills
Novice MPLab X/XC8 skills
The Problem
I am having trouble verifying that my new PICKit4 Programmer is operating properly. I am rather confident that it is a code issue, but, because the PK4 was not cheap, I want to be confident that everything is working exactly as it should...
The Condition
My code is intended to blink LEDs on Pins 5, 6 and 7… Each for ½ second on - ½ second off, in sequence and continuously. What I am getting is that Pin 7 is illuminating for the full three seconds, blinks off and repeats. Meaning, Pins 5 and 6 are not illuminating, at all.
What I Have Done
I am aware that certain PICKit4 properties must be manually set. So, while initially creating the project, I plugged in the PICKit4 (the PK4 was recognized) and set the
- Tools Properties to Low Voltage.
- Power Properties to power the Target at 5 volts.
- Applied changes.
Then, I
- Set all of the typical project properties. The project does default to Main Project, correctly.
- Created the main and config_bits pages in the Source Folder.
- Copied the config_bits.c page, from a prior project, pasted it into Note Pad, to wash it of any formatting, and copied/pasted onto its tab page.
- Copied the main.c page, from a prior project, pasted it into Note Pad, to wash it of any formatting, and copied/pasted it onto its tab page.
- Adjusted/simplified the to just blink the said pins.
Clean and Build
The project builds successfully, with various complaints that I have learned (previously) are non-consequential.
Make and Program Device
The flash completes and verifies.
So, what am I missing? Thank you for your help!
 * File:   config_bits.c
 * Author: xxx
 *Tees_12F1840_PICKit4_Test
 * Created on January 23, 2022; 12:08pm
 * (C) All Rights Reserved
 * Configuration Bits
// CONFIG1
#pragma config1 FCMEN = OFF  // Failsafe clock monitor disabled
#pragma config1 IESO = OFF  // Internal/external clock switchover disabled
#pragma config1 CLKOUTEN = OFF  // Clock out enable off
#pragma config1 BOREN = OFF  // Brown-out reset disabled
#pragma config1 CPD = OFF  // Data code protection off
#pragma config1 CP = OFF  // Code protection off
// #pragma config1 MCLRE = [INGORED/1Input]  // If Low Voltage Programming is enabled, this bit is ignored.
#pragma config1 PWRTE = OFF  // Power up timer disabled
#pragma config1 WDTE = OFF   // Watchdog timer off
#pragma config1 FOSC = INTOSC  // Internal oscillator, I/O on GP4 and GP5
// CONFIG2
#pragma config2 LVP = ON  // Low-voltage programming enabled
#pragma config2 DEBUG = OFF  // In-Circuit Debugger disabled, ICSPCLK and ICSPDAT are general purpose I/O pins
// #pragma config2 UNIMPLEMENTED = 1  // Coded per DS instructions
// #pragma config2 BORV = 1  // Brown-out reset voltage selection = low trip point
#pragma config2 STVREN = OFF // Stack over/under reset disabled
#pragma config2 PLLEN = OFF  // Phase Lock Loop disabled
// #pragma config2 UNIMPLEMENTED = 111  // Bit 7-5 Coded per DS instructions
// #pragma config2 RESERVED = 1  // Bit 3-2 Coded per DS instructions
// #pragma config2 UNIMPLEMENTED = 11  // Coded per DS instructions
#pragma config2 WRT = OFF  // Flash memory self-write protection disabled
 * File:   main.c
 * Author: xxx
/* The purpose of this project is to investigate the operation of my new PICKit4 Programmer. A Microchip
 * PIC12F1840 is used to perform a typical "Blink Test" as follows:
 LED1 = On Pin 7
 LED2 = On Pin 6
 LED3 = On Pin 5
 Explanations of a Blink Test, for both coding and hardware arrangement, shall not be
 * included, here, as extensive tutorials are readily available on the Internet. */
// Declarations
void resetPinState();
void led1on();
void led2on();
void led3on();
// Definitions
void resetPinState() // Set Pin states as Inputs in order to turn the pins off.
    TRISAbits.TRISA0 = 1; // Pin 7
    TRISAbits.TRISA1 = 1; // Pin 6
    TRISAbits.TRISA2 = 1; // Pin 5
void led1on() {
    LATA = 0b00001; // 0 high = Pin 7
    TRISAbits.TRISA0 = 0; // LED1 illuminated
void led2on() {
    LATA = 0b00010; // 1 high = Pin 6
    TRISAbits.TRISA1 = 0; // LED2 illuminated
void led3on() {
    LATA = 0b00100; // 2 high = Pin 5
    TRISAbits.TRISA2 = 0; // LED3 illuminated
    // Default pin configuration for GPIO pins is Input, therefore terminating unused pins as Inputs is not necessary.
    // To clear pins used to drive LEDs
    resetPinState();
    // Sets Internal Oscillator Frequency to 125KHz.
    OSCCONbits.IRCF = 0b001;
#define _XTAL_FREQ 125000  // The use of  __delay_ms (xxx); requires that the oscillator frequency must be
    // specifically defined.
    while (1) {
        // Flash the LEDs, in sequence, continuously.
        led1on();
        __delay_ms(500);
        resetPinState();
        __delay_ms(500);
        led2on();
        __delay_ms(500);
        resetPinState();
        __delay_ms(500);
        led3on();
        __delay_ms(500);
        resetPinState();
        __delay_ms(500);
I ran the Clean and Build again, to get this…
CLEAN SUCCESSFUL (total time: 112ms)
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory 'C:/Users/t1dun/Documents/HP Compaq/Documents/PICKit2and4/PICKit4/PICKit4 Test/PICKit4_Test.X'
make  -f nbproject/Makefile-default.mk dist/default/production/PICKit4_Test.X.production.hex
make[2]: Entering directory 'C:/Users/t1dun/Documents/HP Compaq/Documents/PICKit2and4/PICKit4/PICKit4 Test/PICKit4_Test.X'
"C:\Program Files\Microchip\xc8\v2.32\bin\xc8-cc.exe"  -mcpu=12F1840 -c   -mdfp="C:/Users/t1dun/.mchp_packs/Microchip/PIC12-16F1xxx_DFP/1.3.90/xc8"  -fno-short-double -fno-short-float -O0 -fasmfile -maddrqual=ignore -xassembler-with-cpp -mwarn=-3 -Wa,-a -DXPRJ_default=default  -msummary=-psect,-class,+mem,-hex,-file  -ginhx32 -Wl,--data-init -mno-keep-startup -mno-osccal -mno-resetbits -mno-save-resetbits -mno-download -mno-stackcall   -std=c99 -gdwarf-3 -mstack=compiled:auto:auto     -o build/default/production/main.p1 main.c
"C:\Program Files\Microchip\xc8\v2.32\bin\xc8-cc.exe"  -mcpu=12F1840 -c   -mdfp="C:/Users/t1dun/.mchp_packs/Microchip/PIC12-16F1xxx_DFP/1.3.90/xc8"  -fno-short-double -fno-short-float -O0 -fasmfile -maddrqual=ignore -xassembler-with-cpp -mwarn=-3 -Wa,-a -DXPRJ_default=default  -msummary=-psect,-class,+mem,-hex,-file  -ginhx32 -Wl,--data-init -mno-keep-startup -mno-osccal -mno-resetbits -mno-save-resetbits -mno-download -mno-stackcall   -std=c99 -gdwarf-3 -mstack=compiled:auto:auto     -o build/default/production/config_bits.p1 config_bits.c
Non line specific message::: warning: (1020) unknown attribute "CONFIGPROG" in chipinfo file "C:/Users/t1dun/.mchp_packs/Microchip/PIC12-16F1xxx_DFP/1.3.90/xc8\pic\dat\ini\12f1840.ini" at line 186
Non line specific message::: warning: (1020) unknown attribute "IDLOCPROG" in chipinfo file "C:/Users/t1dun/.mchp_packs/Microchip/PIC12-16F1xxx_DFP/1.3.90/xc8\pic\dat\ini\12f1840.ini" at line 197
"C:\Program Files\Microchip\xc8\v2.32\bin\xc8-cc.exe"  -mcpu=12F1840 -Wl,-Map=dist/default/production/PICKit4_Test.X.production.map  -DXPRJ_default=default  -Wl,--defsym=__MPLAB_BUILD=1   -mdfp="C:/Users/t1dun/.mchp_packs/Microchip/PIC12-16F1xxx_DFP/1.3.90/xc8"  -fno-short-double -fno-short-float -O0 -fasmfile -maddrqual=ignore -xassembler-with-cpp -mwarn=-3 -Wa,-a -msummary=-psect,-class,+mem,-hex,-file  -ginhx32 -Wl,--data-init -mno-keep-startup -mno-osccal -mno-resetbits -mno-save-resetbits -mno-download -mno-stackcall -std=c99 -gdwarf-3 -mstack=compiled:auto:auto      -Wl,--memorysummary,dist/default/production/memoryfile.xml -o dist/default/production/PICKit4_Test.X.production.elf  build/default/production/main.p1 build/default/production/config_bits.p1
Memory Summary:
    Program space        used    6Bh (   107) of  1000h words   (  2.6%)
    Data space           used     3h (     3) of   100h bytes   (  1.2%)
    EEPROM space         used     0h (     0) of   100h bytes   (  0.0%)
    Configuration bits   used     0h (     0) of     2h words   (  0.0%)
    ID Location space    used     0h (     0) of     4h bytes   (  0.0%)
make[2]: Leaving directory 'C:/Users/t1dun/Documents/HP Compaq/Documents/PICKit2and4/PICKit4/PICKit4 Test/PICKit4_Test.X'
make[1]: Leaving directory 'C:/Users/t1dun/Documents/HP Compaq/Documents/PICKit2and4/PICKit4/PICKit4 Test/PICKit4_Test.X'
BUILD SUCCESSFUL (total time: 9s)
Loading code from C:/Users/t1dun/Documents/HP Compaq/Documents/PICKit2and4/PICKit4/PICKit4 Test/PICKit4_Test.X/dist/default/production/PICKit4_Test.X.production.hex...
Program loaded with pack,PIC12-16F1xxx_DFP,1.3.90,Microchip
Loading completed
t1d
Re: Problem verifying that my new PICKit4 is working properl
Postby ric » Tue Feb 01, 2022 6:14 am
All the build warnings are due to using the latest tool pack with XC8 v2.32.
They don't cause a problem, but updating to XC8 v2.35 should remove the warnings.
Which way around are your LEDs connected?
i.e. should they light when the PIC pin is high, or when it is low?
Postby AussieSusan » Wed Feb 02, 2022 3:12 am
Set the TRIS register bits once at the start of the app. Then use the LAT register to turn the pins on and off.
What could be happening is that setting the TRIS register to 'input' stops the pin being driven by the output flip-flop (as per Figure 12-1 of the data sheet) and so it will 'float'. What that does to the LED will depend on actual circuit.
Minor point: I would NOT set the DEBUG config item at all. The IDE will set that for you when you select the 'Debug' or 'Release' build option.
