PID Digitsl controller
Hello friends, I am creating a digital PID controller. The values of Kp and Ki had already been calculated mathematically. It does the PID but, the system should stabilize in approximately 2.04s, and this does it in 3 approx. (attached Proteus image) .If I modify the value of Kp or Ki, the system does the same, there is no change and I do not understand why. If anyone could help me with this please. I also get a warning message on proteus. Attached code and images. I would appreciate your help.
#include <18F4550.h>
#device ADC=10
#use DELAY(internal=4MHZ)
#fuses XT,NOWDT
int16 PID_output;
float Ap=0, Ai=0; //Variables, floating of 32 bits
float max=255,min=0.0; //anti-windup
float Rs, Ys,e; //Variables of PID
float value;
float Us; //Float variables
int8 range; // Magnitude of control action.
float e0;
//PID control
void PID_control() {
float Ki;
float Kp=2.066;
float Ti=0.1597;
Ki= Kp/Ti;
Ap = e*Kp; //Kp, Ki calculation according to algoritm
Ai = e*Ki+e0;
Us = Ap+Ai; //Control action calculation m(kT)
if( Us>max ) { //Anti windup.
Us=value;
else {
if(Us<min){
Us=value;
PID_output = ((int16)(Us));
if(PID_output>255.0) PID_output = 255.0; //Limiting control action to 255
range = (int)PID_output; //Changing float to an 8 bits int
#INT_TIMER2
void main() {
setup_port_a(ALL_ANALOG); //All port A pines analog
//set_tris_a(0b00111111); //Port A as input
setup_adc(ADC_CLOCK_INTERNAL); //Allow A/D converter with internal clock
setup_timer_2(T2_DIV_BY_16, 255,1);
setup_ccp1(CCP_PWM); //Configure CCP1 module with PWM
setup_comparator(NC_NC_NC_NC);
setup_oscillator(OSC_4MHZ|OSC_INTRC);
while(TRUE) {
set_adc_channel(1);
delay_us(10);
value=READ_ADC(); //read value of reference
Rs=(value)*5/1023.0;
set_adc_channel(0);
delay_us(10);
value=READ_ADC(); ////read value variable measured
Ys=(value)*5/1023.0;
e=Ys-Rs; //Error calculation
PID_control(); //Calling PID function
set_pwm1_duty(range);//PWM according to the magnitude of the calculated control action
e0=Ai;
#device ADC=10
#fuses XT,NOWDT
int16 PID_output;
float value;
float e0;
//PID control
float Ki;
float Kp=2.066;
float Ti=0.1597;
Ki= Kp/Ti;
Ai = e*Ki+e0;
Us=value;
else {
if(Us<min){
Us=value;
#INT_TIMER2
void main() {
while(TRUE) {
set_adc_channel(1);
delay_us(10);
set_adc_channel(0);
delay_us(10);
e0=Ai;
