Very basic EEPROM question: always reads as zero
I tried writing and reading the EEPROM on my PIC18F46K80, and it always reads back as zero.
I'm writing in C and using XC8 functions: eeprom_write() and eeprom_read(). I also tried
using the __EEPROM_DATA macro.
What am I missing?
Thanks!
Here's my code:
...and here's what those printfs output:
Initial read of EEPROM[0-7]: 0 0 0 0 0 0 0 0
Wrote EEPROM[27] non-zero, got 0
Wrote EEPROM[28] non-zero, got 0
What am I missing?
Thanks!
Here's my code:
#ifndef __18F46K80
#define __18F46K80
#warning "Code is targeted for PIC18F46K80"
#endif
#pragma config RETEN = OFF // VREG Sleep Enable bit (Ultra low-power regulator is Disabled (Controlled by REGSLP bit))
#pragma config INTOSCSEL = HIGH // LF-INTOSC Low-power Enable bit (LF-INTOSC in High-power mode during Sleep)
#pragma config SOSCSEL = DIG // SOSC Power Selection and mode Configuration bits (Digital (SCLKI) mode)
#pragma config XINST = OFF // Extended Instruction Set (Disabled)
#pragma config FOSC = HS1 // Oscillator (Internal RC oscillator, CLKOUT function on OSC2)
#pragma config PLLCFG = OFF // PLL x4 Enable bit (Disabled)
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor (Disabled)
#pragma config IESO = OFF // Internal External Oscillator Switch Over Mode (Disabled)
#pragma config PWRTEN = OFF // Power Up Timer (Disabled)
#pragma config BOREN = OFF // Brown Out Detect (Disabled in hardware, SBOREN disabled)
#pragma config BORV = 3 // Brown-out Reset Voltage bits (1.8V)
#pragma config BORPWR = ZPBORMV // BORMV Power level (ZPBORMV instead of BORMV is selected)
#pragma config WDTEN = OFF // Watchdog Timer disabled
#pragma config WDTPS = 1024 // Watchdog Postscaler (1:1024), so every 4.096 seconds
#pragma config CANMX = PORTB // ECAN Mux bit (ECAN TX and RX pins are located on RB2 and RB3, respectively)
#pragma config MSSPMSK = MSK7 // MSSP address masking (7 Bit address masking mode)
#pragma config MCLRE = ON // Master Clear Enable (MCLR Enabled, RE3 Disabled)
#pragma config STVREN = ON // Stack Overflow Reset (Enabled)
#pragma config BBSIZ = BB2K // Boot Block Size (2K word Boot Block size)
#pragma config CP0 = OFF // Code Protect 00800-03FFF (Disabled)
#pragma config CP1 = OFF // Code Protect 04000-07FFF (Disabled)
#pragma config CP2 = OFF // Code Protect 08000-0BFFF (Disabled)
#pragma config CP3 = OFF // Code Protect 0C000-0FFFF (Disabled)
#pragma config CPB = OFF // Code Protect Boot (Disabled)
#pragma config CPD = OFF // Data EE Read Protect (Disabled)
#pragma config WRT0 = OFF // Table Write Protect 00800-03FFF (Disabled)
#pragma config WRT1 = OFF // Table Write Protect 04000-07FFF (Disabled)
#pragma config WRT2 = OFF // Table Write Protect 08000-0BFFF (Disabled)
#pragma config WRT3 = OFF // Table Write Protect 0C000-0FFFF (Disabled)
#pragma config WRTC = OFF // Config. Write Protect (Disabled)
#pragma config WRTB = OFF // Table Write Protect Boot (Disabled)
#pragma config WRTD = OFF // Data EE Write Protect (Disabled)
#pragma config EBTR0 = OFF // Table Read Protect 00800-03FFF (Disabled)
#pragma config EBTR1 = OFF // Table Read Protect 04000-07FFF (Disabled)
#pragma config EBTR2 = OFF // Table Read Protect 08000-0BFFF (Disabled)
#pragma config EBTR3 = OFF // Table Read Protect 0C000-0FFFF (Disabled)
#pragma config EBTRB = OFF // Table Read Protect Boot (Disabled)
#include <pic18.h> // Should bring in p18f46k80.h too
#include <stdio.h> // For printf
__EEPROM_DATA(0x11,0x22,0x33,0x44,0x55,0x66,0x77,0x88);
void main()
TRISA = TRISB = TRISC = TRISE = RDPU = 0; // Benign
TMR0 = 0, T0CON = 0x80; // 1MHz (Fosc/4 (=2MHz), prescale 2:1), start running
printf("Initial read of EEPROM[0-7]: %u %u %u %u %u %u %u %u\r\n",
eeprom_read(0), eeprom_read(1), eeprom_read(2), eeprom_read(3),
eeprom_read(4), eeprom_read(5), eeprom_read(6), eeprom_read(7));
eeprom_write(27, 42);
while(WR)
continue;
printf("Wrote EEPROM[27] non-zero, got %u\r\n", eeprom_read(27));
eeprom_write(28, 0xff);
while(WR)
continue;
printf("Wrote EEPROM[28] non-zero, got %u\r\n", eeprom_read(28));
continue;
void putch(char c) // For printf...bit-bang serial I/O
unsigned int shifter, next_bit;
char i;
shifter = c;
shifter <<= 1; // Move left, leaving START=0 bit
shifter |= 0x600; // OR in two STOP=1 bits
while (TMR0 > 0xf800) // Spin if we're within 2 ms of TMR0 wrapping
continue;
next_bit = TMR0 + 104;
for (i=0; i<11; i++)
LATBbits.LATB5 = (0x1 & shifter); // Non-inverted output
shifter >>= 1; // Right shifter (start, then LSB->MSB, then stop, stop)
while (TMR0 < next_bit) // Spin until time for next bit
continue;
next_bit += 104; // 9600 baud = 104 usec per bit
LATBbits.LATB5 = 1; // Back to idle
