Is it possible to write two files simultaneously in usb?
I am trying this code technicalyy the codes has no compile error. it is also running but only on file is being saved.
Can anyone point out what I missed?
CODE:
if i try different formant for different files such as .txt and .csv .I can see the envelope of second file but there is no data in it and it is corrupted.
Thank you.
CODE:
//initialization
#ifndef MINIMUM_BUILD
volatile BYTE logBufferReading;
BYTE logBufferWriting;
volatile BYTE logBufferReading2;
BYTE logBufferWriting2;
LOGGER_STATUS loggerStatus;
volatile DWORD currentTick;
volatile LOG_DATA logData[NUM_LOG_BUFFERS];
volatile LOG_DATA logData2[NUM_LOG_BUFFERS];
FSFILE *filePointer2;
FSFILE *filePointer4;
void LoggingRoutine(void)
char oneChar;
SearchRec searchRecord1;
int d=0;
No_samples=0;
// DispL2(0);
LoggingON = TRUE;
MStat[0]=1;
MStat[1]=1;
MStat[2]=1;
ch2scanflag=1;// this enables the file pointer4 to open write and close
logBufferReading = 0;
logBufferWriting = 0;
logBufferReading2 = 0;
logBufferWriting2 = 0;
ReadingCount = 0;
previousTime.l = 0;
ByteCount = 0;
int timeintnew, timeintold=0;
sprintf(Filenameauto,"%.2x%.2x%.2x%.2x.txt",currentDate.mon,currentDate.mday,currentTime.hour,currentTime.min); //generating first file there is no issue with this one
if ((filePointer2 = FSfopen( Filenameauto, "w" )) == NULL)
DispL2(0);
Put_String_LCD( "File access error" );
for (value=0; value<NUM_LOG_BUFFERS; value++)
logData[value].index = 0;
logData[value].bufferFull = FALSE;
sprintf( (char *)&(logData[logBufferReading].buffer[logData[logBufferReading].index]),// saving data in file 1
"PORTABLE BALANCER 5200 \r\n" );
logData[logBufferReading].index=48;
" \r\n" );
logData[logBufferReading].index=50;
sprintf( (char *)&(logData[logBufferReading].buffer[logData[logBufferReading].index]),"%.2x/%.2x/%.2x\r\n",currentDate.mday,currentDate.mon,currentDate.year);
logData[logBufferReading].index=60;
if(ch2scanflag)// entering 2nd file make option
sprintf(Filenameauto2,"%.2x%.2x%.2x%.2xch2.txt",currentDate.mon,currentDate.mday,currentTime.hour,currentTime.min); // 2nd file generation with //different name
if ((filePointer4 = FSfopen( Filenameauto2, "w" )) == NULL)
DispL2(0);
logData2[value].index2 = 0;
logData2[value].bufferFull2 = FALSE;
sprintf( (char *)&(logData2[logBufferReading2].buffer2[logData2[logBufferReading2].index2]),
logData2[logBufferReading].index2=48;
" \r\n" );
logData2[logBufferReading].index2=50;
sprintf( (char *)&(logData2[logBufferReading2].buffer2[logData2[logBufferReading2].index2]),"%.2x/%.2x/%.2x\r\n",currentDate.mday,currentDate.mon,currentDate.year);
logData2[logBufferReading2].index2=60;
while (c<1.6)
MonitorMedia();
currentTime.l = PIC24RTCCGetTime();
currentDate.l = PIC24RTCCGetDate();
if (timeintnew != timeintold)
FrequencyScan(); // Get the latest reading
sprintf((char *)&(logData[logBufferReading].buffer[logData[logBufferReading].index]),"%05.1f,%07.2f \r\n",Amount1,c);
logData[logBufferReading].index+=16;
if ((logData[logBufferReading].index)+17 > MAX_LOG_BUFFER_SIZE)
logData[logBufferReading++].bufferFull = TRUE;
if (logBufferReading >= NUM_LOG_BUFFERS)
// timeintold=timeintnew;
if (logData[logBufferWriting].bufferFull)
WriteOneBuffer( filePointer2, (BYTE *)logData[logBufferWriting].buffer, logData[logBufferWriting].index );
KEY;
if (U2STAbits.URXDA)// not sure if this one is necessary
oneChar = UART2GetChar();
if(ch2scanflag)
sprintf((char *)&(logData2[logBufferReading2].buffer2[logData2[logBufferReading2].index2]),"%05.1f,%07.2f \r\n",Amount1,c);
logData2[logBufferReading2].index2+=16;
if ((logData2[logBufferReading2].index2)+17 > MAX_LOG_BUFFER_SIZE)
logData2[logBufferReading2++].bufferFull2 = TRUE;
if (logBufferReading2 >= NUM_LOG_BUFFERS)
} // timeintold=timeintnew;
if (logData2[logBufferWriting2].bufferFull2)
WriteOneBuffer2( filePointer2, (BYTE *)logData2[logBufferWriting2].buffer2, logData2[logBufferWriting2].index2 );
} // end of while loop
sprintf((char *)&(logData[logBufferReading].buffer[logData[logBufferReading].index]),"\r\n***********\r\n ");
if(ch2scanflag)
sprintf((char *)&(logData2[logBufferReading2].buffer2[logData2[logBufferReading2].index2]),"\r\n***********\r\n ");
while (logData[logBufferWriting].bufferFull) // Write all remaining buffers to the file
// If the last buffer isn't full but it has data, write the data we have.
if (logData[logBufferWriting].index)
if(ch2scanflag)
sprintf((char *)&(logData2[logBufferReading2].buffer2[logData2[logBufferReading2].index2]),"%02d \r\n ",peakcountno);
while (logData2[logBufferWriting2].bufferFull2) // Write all remaining buffers to the file
WriteOneBuffer2( filePointer4, (BYTE *)logData2[logBufferWriting2].buffer2, logData2[logBufferWriting2].index2 );
if (logData2[logBufferWriting2].index2) // If the last buffer isn't full but it has data, write the data we have.
FSfclose( filePointer4 );// closing files
FSfclose( filePointer2 );
}// end of frequency scan
///function write one buffer
Function:
void WriteOneBuffer( FSFILE *fptr, BYTE *data, WORD size )
Description:
This function writes one log buffer to the indicated file. It then
advances the pointer to the current buffer to write.
Precondition:
None
Parameters:
FSFILE *fptr - Pointer to an open file
BYTE *data - Pointer to data to write
WORD size - How many bytes of data to write
Return Values:
None
Remarks:
None
if (FSfwrite( data, 1, size, fptr) != size)
PrintString( "! Error writing log file\r\n" );
logData[logBufferWriting].bufferFull = FALSE;
logData[logBufferWriting].index = 0;
logBufferWriting++;
if (logBufferWriting >= NUM_LOG_BUFFERS)
void WriteOneBuffer2( FSFILE *fptr, BYTE *data, WORD size )
logData2[logBufferWriting2].bufferFull2 = FALSE;
logData2[logBufferWriting2].index2 = 0;
logBufferWriting2++;
if (logBufferWriting2 >= NUM_LOG_BUFFERS)
}// end of function
Thank you.
