Next step is to start soldering links and components.
As a hint, I find it easier to place links on first. Remember some holes have two wires passing through.
This is the case for the 3.3V LDO regulator, the LEDs and a resistor. A small capacitor shares a couple of the LDO holes.
The PIC chip goes on last. Again I find the sketch makes it easier to work on the board without the PIC IC as a reference.
I was going to use my spring loaded program lead adaptor on this. But I couldn't get it to work well with the vero board so I soldered a header on later.
Note that some links are under the PIC IC. See 08:
- 08_LinksComponents.jpg (118.92 KiB) Viewed 145271 times
Next power the board prior to placing the PIC on. Check voltages are what the're expected and there are no errors. Then solder the PIC on. See 09:
- 09_PIC_Fitted.jpg (95.33 KiB) Viewed 145271 times
A connector has also been added for the UART signals. What can't be seen in this photo is that later I used tippex correcting fluid to paint the header and write the 0v/Rx/Tx on the side.
The converter was flashed by a PICkit3 with the HEX file shown in the first post. Note rather than a USB connector I have used a flying lead.
The one shown is from an old mouse where the cable became frayed at the entry point. A knot in it stops it being pulled through. See 10:
- 10_USB_Lead.jpg (130.1 KiB) Viewed 145271 times
