problem saving on SD card using fat16
I am not sure if this is the place I should post it... Sorry if it is not.
I am new at the forum and PICs too.
I have a 18F4550. I need to save a signal from ADC (150 Hz max) and put it on a SD card. It should be (according to my reaserch) fat16 (or fat32) becouse I need to save that in a file,so I can make/do the processing of the signal with a computer (Matlab). I have tried to use the mmcsd library and the compiler shows errors and I dont know what am I doing wrong...
I am using CCS 4.13 compiler.
Could please somebody help me???
Where can I find an example or something. What I need is:
1-create a file in the SD
2-read the ADC (this I know how to do it
) and append the data to the file(there is a funtion for that, I suppouse I am using it wrong)
3-Repeat "2" for 8 hours (another reason to use the SD)
Thank you in advance
pd: Obviously english is not my first language, I hope you to underestand
